HELP! Annoying window rattle - BMW Forum - BimmerWerkz.com
Old 07-27-2004, 12:17 AM   #1 (permalink)
wyomingj is an unknown quantity at this point
I have an extremely annoying rattle in my driver's side window (at least that is what I think it is). When I hear the rattle I can press hard enough on the window to make it stop, but as soon as I let go it starts again. I have taken it to the dealership 5 times with no success. They keep telling me it is the door seals, which they have already replaced. Is there any chain of command at BMW where I can hopefully get this resolved? Can I take it to another shop without voiding the warrenty if BMW is unable to fix it (I don't care about the money at this point)? Is there a way to terminate a lease early for cause? I just don't see any reason to continue paying for the privledge of having a miserable car. Dealership has been zero help so far.
wyomingj is offline   Reply With Quote
Old 07-27-2004, 08:26 AM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
You can always call BMW NA (north america)... unless this is a independent bmw dealer.
Old 07-27-2004, 09:33 AM   #3 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Contact this person at BMWNA... Be nice to her and polite on your email and you'll get results! Lots of us in this forum have deal with her and got our problems resolved!
Leonora.Vlaovich@bmwna.com
LOS
Old 09-14-2004, 08:22 PM   #4 (permalink)
terri is an unknown quantity at this point
Yup, it's the door seals. My 2004 530 is making "creeking" noises around the window/door seals. It sounds like I'm inside an old wooden sail ship. When I drive with the windows slightly cracked, there's no noise. It happens especially when going over speed bums or dips in the road. It's a defective design by BMW. There are two rubber seals that meet around the windows. I've taken my car into the dealership 5 times as well and all they do is spray a silicone lubricant but the noise comes back after a couple of days and it gets worse! I read somewhere in this forum that a replacement of the seals is only temporary. It's so embarrasing because others can hear it. It definitely does not make BMW look good. I've already told many of my friends, co-workers, neighbors, you name it, NOT to buy the new 2004 5 series BMW until they get all these little defects fixed.
I feel your frustration.
terri is offline   Reply With Quote
Old 09-16-2004, 03:26 PM   #5 (permalink)
ErikB is an unknown quantity at this point
I had a ticking noise in my door. A creaking is from the door seals, but the ticking I had was actually do to a need for some lubricant on the door stop (that plastic thing on othe front of the door that slides in and out of the door when you open and close it. At the back of it (on the firewall side) there is a hinge behind the rubber grommet that surrounds it. I lubed that and the ticking was gone. The noise I had didn't sound like it was coming from there, but it was . . . Good luck.
ErikB is offline   Reply With Quote
Old 09-20-2004, 01:30 PM   #6 (permalink)
After bringing it back to the dealer again they finally located the problem. The problem is with a loose bolt in the door. They "fixed" it once, but it returned after two days. I am now pursuing legal action as BMW has absolutley exhausted all good will with me. Fortunately I live in Louisiana where redhibition laws make it fairly easy to correct these sorts of problems with manufacturers that believe they can get away with anything. Will never buy a BMW again, will always tell everyone what horrible service they have.
Called BMW-NA several times to try and get this situation corrected without legal action never got anywhere.
Annoying Window Rattle 3 Series bmulder1 3-Series (E46, E90) 3 08-10-2005 08:39 PM
E39 Annoying Window Rattles Markowner 5-Series (E12,E28, E34, E39, E60) 4 07-29-2005 03:51 PM
Annoying Engine Rattle Issue scorn6 3-Series (E36) 6 04-20-2005 09:17 PM
Annoying Window Problems... d3ity 5-Series (E12,E28, E34, E39, E60) 0 12-02-2004 12:05 AM
Annoying Rattle In 1998 528i Fuelish528i 5-Series (E12,E28, E34, E39, E60) 2 11-24-2004 09:03 PM
