Originally Posted by dirty87e30m20b27 I am helping a friend put his 2.7I engine in and ran into a hiccup the 88 seta bottom end and trans came out of a 1988 528. The problem i am having is the tail housing output excepts the large flex disk and the drive shaft is the small flex disk take the small flex disk?
Can i swap the the tail output flange from the other G260 i have with the small output flange???????? |
l????? Do 5 series from 1986 - 1988 use d different flex disks that connect the trans to the driveshaft?????
