HELP!! 530d Turbo Failure or Not??? - BMW Forum - BimmerWerkz.com
Old 02-27-2004, 06:04 PM   #1 (permalink)
hyeung is an unknown quantity at this point
HELP! I need some quick advice on this subject.
We have a 530d 2000 model (30k miles only) which has shown some major problems recently. The symptoms are as follows:
Full foot on the accelerator and literally nothing happens!! There doesn’t seem to be any power what so ever?? You do see the revs trying to build up but ever so slowly. It takes about 20-30 secs before it reaches 3k. But once it goes above 3k rpm the power seems to surge back into life. Basically, when we're under 3k rpm nothing really happens.
I really need to keep the revs in the 3k range, otherwise the car really struggles to get anywhere.
Also during a cold start it sometimes really struggles to rev when idle.
Full foot on gas and it sits at 1100rpm.....eventually it slowly revs up the full range.
Anyways, the car is currently at the dealership and it’s taken them the whole day to work out what’s wrong. They now come back and mention it needs a new turbo!
Based on the symptoms, can anyone verify the dealer’s recommendations of a new turbo?
It’s strange since I phoned early today and they tell me the turbo is fine, and are currently testing the MAF meter. I call again and they are still trying to fine the fault. At the end of the day they call and leave a message saying it needs a new turbo.
It just sounds as if they cant really pin point the fault and end up suggesting the turbo needs replacing. I just can’t believe this as the car has recently had a service at the same dealership. After this service we haven’t been using the car for almost 2 weeks (away in holiday), but when we come back and start using the car it fails!
I'm frighten to call them back to find what the cost would be involved.
Unfortunately I’m not knowledgeable in cars and would like some advice on what you think the dealer is saying.
hyeung is offline   Reply With Quote
Old 02-28-2004, 10:37 AM   #2 (permalink)
EXtech's Avatar
ohh how completely WRONG your dealership is. Turbos fail over time, they do NOT fail overnight. When turbos begin to fail, you will notice excessive smoke from the exhaust (oil burning), a loss in boost pressure (if a boost gauge is installed) and a loss in power. To keep a long story short, you do not need a new turbo. You have a electronic issue. I think they need to focus back on the MAF meter. Could also be a camshaft position sensor. There are just too many possibilities but a bad turbo is not one of them (based upon your information).
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 02-28-2004, 03:34 PM   #3 (permalink)
They tried swapping the MAF meter and this had no effect. Still giving the same loss in power. So cant be the MAF meter...
Old 02-28-2004, 06:24 PM   #4 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
don't you have a warranty ?
obd 2 scanner migh be helpful in finding what is wrong
Old 02-29-2004, 04:36 AM   #5 (permalink)
Its a 2000 model, so over the 3 years.....no warranty
Old 02-29-2004, 10:51 AM   #6 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
sorry... i though bmw had 5 yr warranty
Old 02-29-2004, 01:02 PM   #7 (permalink)
EXtech's Avatar
well if it's not the MAF, it's something else. If the turbo was gone the power loss would be linear across the rpm range. Sounds like you might need to find another dealer. A competent dealership should be able to diagnose your problem.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 02-29-2004, 01:26 PM   #8 (permalink)
Am i right in saying that even if the turbo was dead and gone.....Surely the car should still be able to drive off without any issues....wont be as quick but should still be able to shift itself within the 1-3krpm range? Its a 3 litre engine...
At the moment the symptoms are that it barely moves when you have full gas within the 1-3k rpm range.
Old 02-29-2004, 01:59 PM   #9 (permalink)
Michael@EuroPersona's Avatar
Michael@EuroPersona is an unknown quantity at this point
Send a message via ICQ to Michael@EuroPersona Send a message via AIM to Michael@EuroPersona
To tell you the truth its a Diesel engine, so I dont know much about it, But I do Know that diesel have turbos for a reason.. To get going easier.. So the turbo MIGHT be the problem..
So I dont agree or disagree with anyones statements.. I would have the dealership do the work, And if it doesnt fix the problem, but first make sure they will reimbuse you if thats not the problem.. also By telling them that you might show that you know a thing or 2 and MAYBE they might actually do a correct diagnosis.. The dealership your going to is a BMW dealership right?
Im not a BMW dealership, but If I fix someones car and it doesnt work right I continue to work on it until its fixed, and free of any additional charges.. I know not all shops are like this, but thats how I work!
**deleted** We do not allow commercial activity from non supporting vendors.
Michael@EuroPersona is offline   Reply With Quote
Old 02-29-2004, 08:33 PM   #10 (permalink)
EXtech's Avatar
yes hyeung it would still be able to accelerate and from what you described it won't. It's not the turbo. Any competent technician (especially a BMW trained one) could tell you that.
Here's some food for thought. I have a 2002 Ford F250 4x4 diesel and on very cold mornings (35 and below) there is a bypass valve that will allow the boost pressure to bleed off rather than fill the engine. This is done to avoid damaging a cold diesel engine. Diesels run very cold temps (compared to gasoline engines) and take forever to reach a normal operating temp on a cold day. The boost is bypassed while warming so as not to load the engine while cold. I can pull out of the driveway and for a couple miles there is no boost. I putt along and just as I reach the heavy traffic the engine has warmed and now the boost will build. The point is, your engine still makes power regardless of turbo boost. If the turbo was not making boost you should still be able to accelerate. Granted, it will not accelerate near what it does with boost but it will accelerate. Something is going on with your car relating to load sensing. I say this because once it reaches 3k it runs fine. It could be a cam sensor, a boost reference sensor etc. Honestly, with my years as a bmw tech, I never came across a bmw diesel and that's probably the problem with your dealership. However, it's not rocket science especially if you have the car in front of you. They should be able to diagnose the problem and fix it. Diesels are actually quite simple and you don't have an ignition system so that's one less thing to worry about. All that you need with a diesel is air and fuel. Good luck.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 03-06-2004, 07:25 AM   #11 (permalink)
Just an update on the problem.
It has now been resolved. The dealer has fitted a new turbo and all seems to be good again. The good thing is that BMW GB is paying 100% on the parts. So it turns out i only need to pay £282 for the labour costs. Which isnt bad seeing the car is out of the warranty period.
Thanks again for everyones input......
Old 03-10-2004, 11:20 PM   #12 (permalink)
EXtech's Avatar
there must be something missing here... from what your symptoms were, a turbo would not cause, unless I misunderstood you.
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 11-11-2006, 07:15 PM   #13 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
If you run a turbo'ed car hard for a while and just park it till it cools down without letting the car idle(too cool the turbo) doesn't the turbo freeze up used: from over heating the turbo and bearings??? this happend to my friends supra(was running 13psi boost) he raced around then parked it without letting the turbo cool and the turbo said you no play no more bye bye and it died
1992 318i Coupe parts car
I am Captain Obvious
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Bmw Track Times dutchbmw Bimmer Talk/Motorsports Talk 2 06-25-2005 08:05 AM
Custom M3 Turbo Vs Aa Turbo M3 NyteRyda Video Vault 3 04-23-2005 09:20 PM
