Heater Problem in 1985 528e - BMW Forum - BimmerWerkz.com
Old 12-05-2003, 06:05 AM   #1 (permalink)
mahill69 is an unknown quantity at this point
I recently bought this car and its great except no heat from the center vents. The defrostand foot vents are hot. But the center vents are always cold even when I adjust the little dial in the middle of the dash. It would be nice to have heat for me hands 2!!! Any ideas?????
mahill69 is offline   Reply With Quote
Old 12-14-2003, 02:09 PM   #2 (permalink)
Wurzig-Drei's Avatar
Wurzig-Drei is an unknown quantity at this point
Send a message via AIM to Wurzig-Drei
In my 85 528e i have some major heat issues. When the fan is running for the heat, it squeakes like crazy and vibrates the whole car. Then sometimes it wont turn on at all, but when i hit A/C button the fan starts turning, when i turn off A/C the fan stops turning. Also if the fan isnt turing for the heat, when i start from a complete stop, it starts turning again, unless i turn it off and try to turn it back on again, then it stops and wont turn back on. I need some help.
Under construction
Wurzig-Drei is offline   Reply With Quote
Old 12-14-2003, 02:16 PM   #3 (permalink)
Chooch is an unknown quantity at this point
fan may need to be tightenend ... check for lose belts ... possible bad connection somewhere ....
<span style='color:blue'><span style='font-family:Arial'>If I try to be like everyone else, who's going to try and be like me?</span></span>
<span style='color:blue'><span style='font-family:Arial'>Mi casa no es su casa, hijo de puta.</span></span>
Chooch is offline   Reply With Quote
Old 12-17-2003, 01:54 AM   #4 (permalink)
When i accelerate really hard, the heat will suddenly turn on, but it makes a god aweful grinding/squeaking noise where my windshield meets the dash. The fan under the radio does not squeak. Is there a seperate fan in the dash that i do not know of?
Under construction
Old 12-17-2003, 02:03 AM   #5 (permalink)
Iv got a 1985 528e with the same problem, have you figured out the problem yet?
Under construction
Old 12-17-2003, 03:02 AM   #6 (permalink)
No, I really ahven't even looked at it yet since I have pleanty of heat for the defrost and floor. Will get back to you after I investingate.
MH
Old 12-17-2003, 03:56 AM   #7 (permalink)
SoonerE39's Avatar
SoonerE39 is an unknown quantity at this point
Send a message via AIM to SoonerE39
I heard others complaining of this same problem. You said you've tried turning the wheel in the center of the vents to hot and that didn't work. When you turn that wheel, does it feel like it is connected on the other side? I'm wondering if it is disconnected from the part it moves on the other side of the wheel?
[CODE]&lt;EMBED src=&quot;http://members.cox.net/toakes2/Copy%20(2)%20of%20toms%20sig.swf&quot;quality=high bgcolor=#000000 WIDTH=420 HEIGHT=220 TYPE=&quot;application/x-shockwave-flash&quot; PLUGINSPAGE=&quot;http://www.macromedia.com/shockwave/...&lt;/EMBED&gt;
Sig by Woobiee
<img src='http://www.ousooners.net/Avatars/Tx_Smack/lh_rip.gif' border='0' alt='user posted image' />
1999 528i 5 Speed, Sport Package, Confortti Software, Racing Dynamics Front Lip Spoiler and Rear Apron, Supersprint Muffler, Angel Eyes Upgrade.
SoonerE39 is offline   Reply With Quote
Old 12-17-2003, 03:57 AM   #8 (permalink)
SoonerE39's Avatar
I'll merge with the other heater question thread.
Sig by Woobiee
Old 12-17-2003, 04:22 AM   #9 (permalink)
The center wheel does not feel like it's connected to anything. I figured it was just a veriable resistor and did not expect any feel or feedback from the dial. I will check the dial tonight.
Thanx!
Old 12-17-2003, 06:09 PM   #10 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
The center vents are not supposed to put out heat. That is the way the HVAc system is designed in the E28 models.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Old 12-17-2003, 06:17 PM   #11 (permalink)
E28boi's Avatar
The earlier E28 utilizes 2 fans. One for the a/c and one for the heater. IIRC the 87&88 models have only one fan for both. These fans are located above the ashtray in the center console. The problem with the squeeking is caused by a bad bearing. Your intermittent problem is either a bad ground or loose connection.
86 535i
99 Passat V6
Old 12-18-2003, 06:09 AM   #12 (permalink)
How would i go about reparing this problem. And are both fans above the ash tray under the radio? or is there another one somewhere else in the car. Cause i know i can see one of them, but i dont see two. And refering to the bad bearing, how would i go about fixing that?
Under construction
Old 12-18-2003, 08:44 AM   #13 (permalink)
E28boi's Avatar
Both are in the console above the ashtray. They are side by side, that's why you think you see one. If you turn the a/c on, the "squirrel cage" on the drivers side will spin, and if you turn the heater blower on the "squirrel cage" on the passenger side will spin.
As for the bad bearing you will have to replace the motor. If you don't want to and can't take the squeeking maybe some lithium grease will help. DO NOT use WD40.
86 535i
99 Passat V6
Heater Problem Bmmf40 5-Series (E12,E28, E34, E39, E60) 1 07-03-2005 11:38 PM
Heater Problem And Oil Problem floydzeppelinfan 3-Series (E36) 1 04-07-2005 10:19 PM
Need Help! Problem With Blower, Heater. DiRay 3-Series (E21, E30) 4 02-15-2005 04:13 PM
528e Heater Help sailor1313 5-Series (E12,E28, E34, E39, E60) 5 11-17-2004 07:17 AM
318IS heater problem jonniwal 3-Series (E36) 1 04-26-2004 12:37 AM
