Heater in moms 2002 525i M wagon - BMW Forum - BimmerWerkz.com
Old 03-01-2012, 12:30 AM   #1 (permalink)
Critter is on a distinguished road
Thumbs up Heater in moms 2002 525i M wagon
Not sure if Im using the right verbage. Car is equiped with driver/passenger climate control. I just took a short trip with my mom and she is FREEZING to death. Passenger side is functioning correctly. Driver side blows air fine but no heat.
I just learned of this and wont even be able to check fuses let alone mess with it for several days.
Any input regarding the dual climate control setup or this issue in particular will be very much appreciated. I dont have a service manual for car either.
Thank you,
Critter
Critter is offline   Reply With Quote
Old 03-01-2012, 07:05 AM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Check the coolant. No heat is a sign of low coolant or possibly air in the system. If its low, try to find any leaks as those will need to be addressed. Top up the fluid ensuring you stay with te same type of coolant that's already in the car. If you have to top t up make sure you bleed the coolant system. One good idea some people recommend is to lift the car a few inches to help the air get to the top.
Click HERE to see my E36 Blog
Old 03-01-2012, 01:46 PM   #3 (permalink)
Thanks for reply. I have been checking oil and coolant on this car bi-weekly for 3 years. No problem with the coolant or its level. As I shared in first post passenger side of dual climate control works fine, max setting is 90f and it will cook your feet. Driver side does not have heat. Adjusting the fan output services both dirver and passenger side equally. But dirver and passenger each have thier own temp control.
I hope to get out there this evening and check fuses. At this point that is all I can do.
Old 03-02-2012, 06:45 PM   #4 (permalink)
Car: looking for a 5- series project car
70marlin is on a distinguished road
Sounds like a heater deck door malfunction, I'd be looking for a lose electrial connection on servo motor or a bad servo motor also a broken deck door shaft could be causing the cold air issue.
Sent from my SPH-D700 using AutoGuide.com App
70marlin is offline   Reply With Quote
Old 03-03-2012, 10:42 AM   #5 (permalink)
Ty
Ill search archives and google see if I can determine where these parts are.
Old 03-03-2012, 11:25 AM   #6 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Also be aware that the Blower Resistor (Hedgehog) can affect the heating system as you say...
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 03-05-2012, 02:05 PM   #7 (permalink)
Car: 1989 BMW 535i
rivroshaun951 is on a distinguished road
Don't waist your time with fuses. A blown fuse would not allow you to have any heat not matter passenger or driver side. I would focus you attention on the doors. You have power, You have Heat, You have air flow. Your problem is not getting heat to the correct location. I would go with 70marlin suggestions.
rivroshaun951 is offline   Reply With Quote
Old 03-06-2012, 02:44 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Hmmm...
Your car may be fitted with those stupid sensors in the vents (bad idea IMO), if one of those fails it can be unpredictable !!
Eso es todo!
BMW Part Market
New Member ?
525i wagon/Beyren's ? Darian 5-Series (E12,E28, E34, E39, E60) 0 09-08-2010 02:10 AM
For Sale: 2002 325it wagon KeithinAL Cars For Sale 12 03-10-2007 01:29 PM
For Sale: 2002 325it Wagon KeithinAL Cars For Sale 0 07-17-2005 01:02 PM
What Ecu Is In My 92 525i Wagon? drifts14x 5-Series (E12,E28, E34, E39, E60) 4 03-03-2005 06:19 AM
Considering To Buy A 2002 325it Wagon maxxx 3-Series (E46, E90) 4 10-16-2004 11:32 PM
