Heat inside E39 Boot - BMW Forum - BimmerWerkz.com
Old 07-28-2007, 09:37 AM   #1 (permalink)
Grand is on a distinguished road
Is it normal for the boot area to get hot after a long ride under hot sun? When i place my hand on the spare wheel, it is very hot, but not to the extent of burning my hand. I mean if the heat insulation within the cabin is good (of course have to take into consideration the cabin are air conded), i expect the heat insulation within the boot area to be quite good too. Could it be because the cat is just below the boot causing the heat to permeate through? Worry about the CD Changer being affected by the intense heat.
Grand is offline   Reply With Quote
Old 07-29-2007, 02:10 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
CD changer and amp probably have a lot to do with the heat you notice.
How's the heat shielding on the underside of your car look? Still have it?
Lindsay fan club member.
Old 07-30-2007, 12:11 AM   #3 (permalink)
heat
Will open the boot and have a good look at it when i finish work today.
Old 07-30-2007, 07:10 AM   #4 (permalink)
Trevize's Avatar
Trevize will become famous soon enoughTrevize will become famous soon enough
Send a message via AIM to Trevize
Odd. I've never noticed any heat/warmth in my E39 M5 boot.
However the M5 is very different from the normal E39 in this area. The quad exhaust takes up the space normally used by the spare tire and I have no spare tire. So I imagine the heat shielding for the quad exhaust is totally different from normal E39's.
Trevize is offline   Reply With Quote
heat inside cab Stunnd65 3-Series (E36) 4 06-29-2009 10:22 PM
NEW! Matching Shifter and E-brake Boot SET E30 E36 get rid of old rubber e-brake boot customshiftboot Aftermarket Parts 1 05-18-2006 11:52 AM
NEW! Matching Shifter and E-brake Boot SET E30 E36 get rid of old rubber e-brake boot customshiftboot Aftermarket Parts 0 03-19-2006 05:20 PM
NEW MATCHING SHIFT & E-BRAKE BOOT SET BMW E30 318 325, E36 shift boot customshiftboot Aftermarket Parts 0 03-01-2006 12:38 PM
Dont Got Heat Inside E21 emmceethree 3-Series (E21, E30) 6 01-19-2005 11:33 PM
