Heard noise when turning steering wheel on my 2005 525i - BMW Forum - BimmerWerkz.com
Old 01-28-2010, 12:58 AM   #1 (permalink)
lovecd is on a distinguished road
Heard noise when turning the steering wheel recently on my 2005 525i. THe noise is more obvious after driving for a while, and hard to hear when car is cold. Thought it mightbe the power steering wheel fluid level is low, try to add some ATF fluid, but the noise is still there. What could be the problem?
Thanks for any advise!
lovecd is offline   Reply With Quote
Old 01-28-2010, 02:56 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Sounds like the power steering pump, as the fluid was low it must have a leak somewhere, whilst stationary with the car running get someone to turn the wheel while you have a listen under the bonnet/hood, it would be better if the front of the car is off the ground...
Old 01-28-2010, 01:12 PM   #3 (permalink)
Thanks for your reply! By the way, what should I see if there is a leak under the hood? Should I remove the bottom cover underneath first?
Also, I did not hear the noise when the car is cold, and only hear the noise after driving for a while. In this case, is this still the pump issue?
Thanks again!
Old 01-29-2010, 03:00 AM   #4 (permalink)
marti5's Avatar
Remove the bottom guard and have a good look around, as said you really need someone to turn the wheel while you listen out....it may not be the pump but something else..
Jerking noise when turning the steering wheel, fully rashid 5-Series (E12,E28, E34, E39, E60) 12 07-28-2009 08:54 PM
noise in steering wheel ksee777 3-Series (E36) 9 04-29-2006 10:43 PM
2005 BMW 520i Steering column cracking noise GPap Looking For 0 11-04-2005 02:40 PM
Steering Wheel Noise Brodees 3-Series (E46, E90) 3 03-03-2005 09:10 AM
