Headlight Question. - BMW Forum - BimmerWerkz.com
Old 06-28-2005, 09:10 PM   #1 (permalink)
nas82 is an unknown quantity at this point
Hi there, new here so go easy on me. I tried searching but couldn't find my answer.
I have a 92 525I and it has to broken lens on the low beam headlight. The bulb is fine, just the glass part is broken.
My question is, are the left and right universal. And what i mean is, could i put the left low beam light on the right side and vice versa?
nas82 is offline   Reply With Quote
Old 06-29-2005, 01:23 AM   #2 (permalink)
Car: 00 Prelude, 95 525i, 85 635CSi
d3ity will become famous soon enoughd3ity will become famous soon enough
I'll give you the short answer.
No.
The right and left are diffrent. You're going to have to buy the specific housing for the side of the car.
<iframe src="http://gamercard.xbox.com/TiddlyPlatypus.card" scrolling="no" frameBorder="0" height="140" width="204">Put your gamertag here too.</iframe>
d3ity is offline   Reply With Quote
Old 06-29-2005, 11:37 PM   #3 (permalink)
They're identical assemblies unless you have a european model car.
Old 06-30-2005, 12:58 AM   #4 (permalink)
billB's Avatar
For OEM, Hella lists them with two different part numbers coupled with 2 different prices!!
( P8039-29674 ) Left side Low....$67
( P8039-29675 ) right side Low...$69
regards
billb
Old 06-30-2005, 01:37 AM   #5 (permalink)
Where did you find those?
Realoem lists different part numbers (and thats to be expected) but the prices are the same.
On a sidenote, I have taken both apart when I converted to HIDs. They are identical units inside and out regardless of part numbers and all that jazz.
Maybe I'd need a closer inspection as one of the mounting tabs may be in a SLIGHTLY different location, but they appeared identical. I'll check in the morning.
HELP!!!!! Headlight Question ASAP!!! stevestarr 3-Series (E36) 4 09-24-2005 04:01 PM
Headlight Question.. Pls Help! gerardog 5-Series (E12,E28, E34, E39, E60) 4 02-23-2005 03:45 AM
the question of the e36 headlight lens shuiyuan 3-Series (E36) 5 08-25-2004 04:35 PM
E34/E32 projector headlight question... karab95 5-Series (E12,E28, E34, E39, E60) 0 06-06-2004 01:43 PM
e46 headlight question woobiee 3-Series (E46, E90) 1 06-01-2003 04:17 AM
