used:
I need to replace the headlights on my 5251 (E34) but am not sure if there is just a lens to replace or if the whole headlight has to be replaced. The dealer cost for a headlight is $159.00-ouch! If I do have to replace the headlights are there any other small piece parts to be needed or can I use anything from the old headlights. The bulbs/lamps are just fine but the lenses are cracked-typical for driving in Colorado.
The least inexpensive place I found for replacement headights was at Euroasian:
www.euroasianautoparts.com and they ran $114.12 and $117.55 respectively for the left and right.
Any Ideas or suggestions would be most helpful.
Thanks in advance.
