hard starting - BMW Forum - BimmerWerkz.com
post #1 of 14 (permalink) Old 01-14-2012, 06:15 PM Thread Starter
westin is on a distinguished road
Question hard starting
Hi ,i have 97 528 53k on it , this is the second post im putting ,i have done some tests and replaced some parts but no luck. I have to crank the car afew times after sitting for a while but it will always start, no check engine light on, once it starts runs fine and it will start right up again if shut it off .A list parts of replaced and tests perfomed
New fuel filter
New crank and cam sensor oem,crank sensor has the updated wiring
New battery (did not start )car had stayed about 4 hours off, whe i replaced batterry the same problem crank twice fired right up
Checked for fuel pressure drop after shut the car off it held pressure 48psi for 45min
When i turn the key to on position 40 psi in rail
Scaned with factory scan tool crank sensor code stored in history i was told, but regular scan tools couldnt pick it up in history or pendnig(snap on modis with european software )thats why replced CPS
If any one has any ideas or any test that should looked into performing, any help would be apriciated
westin is offline
post #2 of 14 (permalink) Old 01-15-2012, 08:52 AM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Obviously a cold-start issue!?
Air-lock in fuel-line? Dunno as yet bud...
Eso es todo!
Jack Dabsy is offline
post #3 of 14 (permalink) Old 01-15-2012, 04:00 PM Thread Starter
im taking it to indy shop again ,see what they come up with this time. Damn this cars 2for 2 both cluster f@#*$
westin is offline
post #4 of 14 (permalink) Old 01-15-2012, 04:01 PM Thread Starter
thanks for the replys,any feedback is apreciated
westin is offline
post #5 of 14 (permalink) Old 01-26-2012, 09:50 PM Thread Starter
car got fixed two modules later,dme defective
westin is offline
post #6 of 14 (permalink) Old 01-27-2012, 01:42 PM
Captain... Savvy ?
Jack Dabsy's Avatar
Quoted: 1 Post(s)
Hard to detect without a laptop eh? Anyway it's sorted so Happy Days again matey...
Eso es todo!
post #7 of 14 (permalink) Old 01-30-2012, 06:25 PM Thread Starter
Thumbs up
thanks man ,hopefuly no breaking my wallet for a while
westin is offline
post #8 of 14 (permalink) Old 02-05-2012, 04:52 PM
congalaig is on a distinguished road
what's a dme?
congalaig is offline
post #9 of 14 (permalink) Old 02-08-2012, 07:23 PM Thread Starter
Engine control module
westin is offline
post #10 of 14 (permalink) Old 02-09-2012, 03:20 AM
42, The meaning of life
brettski's Avatar
brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice brettski is just really nice
And slightly more expensive than a dime
Riding in style
brettski is offline
post #11 of 14 (permalink) Old 05-28-2012, 08:28 PM
I've to count to 14 before starting and then it kicks off first time. i've been talking to everyone but the pope and no ideas. Might as well try the dme!! Where is it located, and what does it look like??
post #12 of 14 (permalink) Old 05-28-2012, 09:49 PM Thread Starter
the dme is just a name for the ecm or ecu what ever you prefer,it looks like most units just type dme on goolge and youll get an idea, on my car its located under the right side cabin filter,i dont know what kind you got so cant say where its located,if you give me a year and model i can find out or google it
westin is offline
post #13 of 14 (permalink) Old 01-29-2014, 04:46 PM
heryrodz is on a distinguished road
I have more less same issue but my car when is cold starts right away, when engine gets to normal operation temperature runs fine for a while but when I stop the engine and try to start it again nothing I have to wait about 10 minutes to do engine runs again....
heryrodz is offline
post #14 of 14 (permalink) Old 02-04-2014, 01:17 PM Thread Starter
Do you have any codes,check engine light on,any test that you ran,the tech that , found mine hooked up a lab scope to the injectors , and noticed they werent firing,thats why he suspected a crank sensor,wich wasnt the case,the control module for whatever reason wasnt waking up , until I crank it a few times,the capacitors might have been junk,had simmilar problem witha cluster,on the e34,the reason behind it its just speculation, on my part,either way the module got replace d, never had a problem again,so check before you replace anything,dme on my car , being that old did have to reprogramed, if it did I dont htink a used module would have worked,let me know if you any help, good luck
westin is offline
2001 e39 530i has a hard time starting in the cold kdominating 5-Series (E12,E28, E34, E39, E60) 7 02-06-2011 12:57 AM
E46 330i hard starting after winter storage - anyone else? nopcbs-1 3-Series (E46, E90) 7 05-09-2009 05:29 PM
94 740 IL - Hard Starting...now won't start bosox406 1,6,7,8 - Series and Mini Cooper 4 01-24-2006 01:29 PM
Hard Starting '91 325i adavis 3-Series (E21, E30) 24 04-07-2005 11:06 AM
this is too hard for me to do tico481 Picture Showroom 2 09-06-2004 03:43 PM
