glow plug relay - BMW Forum - BimmerWerkz.com
Old 12-21-2008, 11:55 AM   #1 (permalink)
Car: 98 525tds,00 316i,93celica4ws GTR
tarlac is on a distinguished road
Send a message via Yahoo to tarlac
glow plug relay
Can anybody tell me where the glow plug relay is on a '98 525tds?
tarlac is offline   Reply With Quote
Old 12-21-2008, 12:13 PM   #2 (permalink)
Have you looked in the ECU box (in the engine compartment)?
Old 12-21-2008, 06:42 PM   #3 (permalink)
I can't find an ecu box in the engine compartment. There's a fuse box in the glove box but it has no relays.
Old 12-22-2008, 08:24 AM   #4 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Strange you should have on your car 2 black boxes under the hood one in each corner at the rear next to the fire wall, if i remember correct they have clips on them , one of these boxes contain the relays.
Old 12-25-2008, 07:47 PM   #5 (permalink)
thankyou marti5. Had just worked that out. I put this engine in about two months ago and started getting busted pipes on the injectors. I replaced all them. everything back to the fuel filter and even replaced that. still need a toe-start. When its warmed up its fine. So reckoned the heater plugs had calved so replaced all them with a new set of bosch. Still need a toe to start in the mornings. so reckoned might be the relay but apparently they very rarely go. don't know. It's a pricey item to replace if it's not the problem. Short of putting it into a dealer what do you think I should do?
Old 12-28-2008, 12:00 PM   #6 (permalink)
do you know where the fuse link for the glow plug relay is on the 98 525tds. I take it it's in the ECU box !
Old 12-28-2008, 12:08 PM   #7 (permalink)
You're looking in all the boxes by now I imagine.
Old 12-29-2008, 06:58 AM   #8 (permalink)
marti5's Avatar
So does it crank over fine and does the glow plug light come on and go off ?.
After youve tow started it and then turn it off does it start up ok, also how long before you cant resart.
Old 12-29-2008, 11:19 AM   #9 (permalink)
It cranks over fine and the glow plug light goes off after 5 or 10 seconds. After I've tow started it it starts up on the first touch. It's really only when I leave it over night that it won't start. If it's been sitting for three or four hours and I turn the engine for ages, it eventually starts with a ball of smoke
Old 12-29-2008, 11:28 AM   #10 (permalink)
I'm going out now to check the fuses in the ECU box (or what looks like fuses in the ECU box). Have already checked those in the glove box.
I've put two engines and done shell bearings three times in this car in the last year. A wise man would have changed long ago.
Old 12-29-2008, 11:49 AM   #11 (permalink)
marti5's Avatar
Sounds to me like a fuel pressure problem, as in the fuel non return valve to the tank, as I have had diesels where one or two plugs go and you dont just get a small amount of smoke you get loads like a fog and it continues for quite a while. The fuel pump only kicks in while cranking the engine and not whilst the ignition is turned on, there should be fuel in the rail, which stays there from when you turn it off, ready for the next morning, but if your non return valve has gone, overnight it will return to the tank, so when you tow it its turning over faster than by key hense the pump is pumping like mad to refill the fuel rail, then she fires up, you say you can leave her for a while,but takes a bit of cranking before she fires up , thats because the fuel has started its return to the tank.
Old 12-29-2008, 01:25 PM   #12 (permalink)
Smile
Just went out and checked the fuses in the ECU and there was a big 30amp blown. Replaced and hey presto.. barring a run-down battery. Here's fingers crossed ... until the next time !!
Thanks to Marti5 and Witeshark
New Spark Plug Wires For All You E30er's(Bavauto Plug Wires) Bmw1990 Product Reviews 2 02-19-2009 02:38 AM
Mountain Dew glow stick....yo yammahamma Video Vault 7 11-05-2007 08:23 PM
E39 Tds Glow Plugs Not Warming Up hanif001 5-Series (E12,E28, E34, E39, E60) 2 06-27-2005 02:39 PM
Which Relay Is The Wiper Relay? Tan One? Eric S. 5-Series (E12,E28, E34, E39, E60) 5 04-24-2005 09:20 AM
