Gearbox oil - BMW Forum - BimmerWerkz.com
Old 10-25-2003, 02:08 PM   #1 (permalink)
BMWhatever is an unknown quantity at this point
The manual says that it should be ATF-type oil (BMW approved of course, what the hell that is) in the manual gearbox and hypoid (SAE 80 oe 90 or something I guess) type in the drive shaft. Now what is ATF-type oil? Is that something similar to the Dextron automatic transmission oil? What is approved by BMW?
BMW 518g touring (e34) -96.
BMWhatever is offline   Reply With Quote
Old 10-25-2003, 11:23 PM   #2 (permalink)
E39 ATF is Dextron 1 and it is no longer available.
Dextron 1 is replaced by Dextron 2.
Completely compatable.
Lots of BMW using Redline ATF
and Redline MTL for hypoid gear grease.
Later,
<img src="http://kcrealtime.com/dyno-max_900_hp.gif">
KC Ron Carter is offline   Reply With Quote
Old 10-26-2003, 03:32 PM   #3 (permalink)
Thanks, do you know what type it should be in the drive shaft (SAE type?).
what engine oil to put in because i dont know if its syntec or normal? träumer 3-Series (E21, E30) 3 11-01-2005 02:40 PM
spark plug drenched in oil Beemerguru 3-Series (E36) 2 10-06-2005 10:06 PM
