Gasket - BMW Forum - BimmerWerkz.com
Old 05-16-2005, 11:03 PM   #1 (permalink)
Rkhoubian is an unknown quantity at this point
Hi friends
I have an oil liking from ( seems to me ) oil filter housing from sides which looks on oil presure switch. Mechanic advise that this a time to change gasket in side of the housing. Does any body know if it is correct.
Thank you for any reply
Rkhoubian is offline   Reply With Quote
Old 05-16-2005, 11:12 PM   #2 (permalink)
antose9 is an unknown quantity at this point
check oil filter gasket - it needs to be oiled before putting oil filter on. cheers-
A9
antose9 is offline   Reply With Quote
Old 05-16-2005, 11:55 PM   #3 (permalink)
RKhoubain is defiantly right about oiling the o-ring before installing it. i have seen the tear when the are installed if they aren't lubed, then you really have a mess on your hands (somtimes literally) after you atrt the car and find out. if it is just a little seepage it could just be from past oil changes though. sometimes the oil can drip down the sides when the filter is taken out and if it isn't all wiped off it can collect dirt and look like a leak. you should change the o-ring everytime you change the filter.
Old 05-24-2005, 06:02 AM   #4 (permalink)
[snapback]345113[/snapback]
But it should not beo ring. Licking from the botom of oil filter housing
Blown Head Gasket? sirmj 3-Series (E36) 6 01-09-2013 08:21 PM
Project: Head Gasket nookatee 3-Series (E36) 1 06-01-2005 10:16 AM
How Tough Is A Vc Gasket Change In A 540? Eric S. 5-Series (E12,E28, E34, E39, E60) 3 11-14-2004 08:55 PM
318is and that pesky timing profile gasket 91redhed 3-Series (E21, E30) 0 09-09-2004 01:18 PM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
