FUSE BOX WIRING... - BMW Forum - BimmerWerkz.com
Old 08-05-2003, 12:08 PM   #1 (permalink)
mimikr is an unknown quantity at this point
Ok.. I have a 1982 528e and the fuse box was melting around the fuse clips for the auxilary fan and blower. I went to a junk yard and found another fuse box for which I just replaced.
Somewhere along the line I must have messed up the wiring as now when I put the key in the first dentent postion the fan will come on if I have the A/C button on and the sunroof will operate as normal but as soon as I put the key in the second detent position and the car is running the fan goes off and I can no longer operate my sunroof.
Please help... I can not drive it this way as it will overheat if the auxilary fan can't operate.
Thanks...
mimikr is offline   Reply With Quote
Old 08-05-2003, 12:42 PM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
The only thing I can think of is that you have a wire crossed somewhere. You may want to go back to start, take it apart, trace teh connections and do it over again. That's the only way I can figure that you would be able to come across the problem.
Sorry I couldn't be of any help!
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 08-05-2003, 11:14 PM   #3 (permalink)
EXtech's Avatar
yeah, sounds like a relay wired backwards. get out the wiring diagram and double check.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
E30 Fuse Box Privateye 3-Series (E21, E30) 5 06-27-2005 09:25 PM
Front Fog Lights Installation & Wiring Paraklas 3-Series (E21, E30) 0 11-04-2004 05:13 PM
Power Rear Vent Window Wiring jswanson3 3-Series (E36) 0 10-28-2004 03:51 PM
Fuse Blade Terminal Clips szidikj 3-Series (E21, E30) 0 08-16-2004 10:59 AM
