Fuel line Questions - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 03-22-2004, 09:54 PM Thread Starter
M5power is an unknown quantity at this point
wanted to see, well my rpm's have been jumping a lil, making my car run shitty. i narrowed it down to my fuel line(im guessing thats why my check engine light has come on) but yeah, so i wanted to see how i can know what part of the fuel system is having the problem? if it is the fuel filter(gonna start with the most inexpensive) how would i know if that is the problem? if i take that out will it be obvious? with my fuel line: is it easy to follow? or does it go through places that it is hard to get to? i haven't seen leaks or anything, but fuel evaporates fast..so its kinda hard. i dont wanna buy one of those pressure checkers because thats about as much as it is for me to get a new fuel line. just lemme know on way to spots this problem please, so i can get my baby back out on the streets.
1985 BMW 528E
<img src='
The b0x that r0x
M5power is offline
post #2 of 3 (permalink) Old 03-23-2004, 06:38 PM
EXtech's Avatar
there are several possibilities that could be causing your problem but I doubt with all certainty that your fuel line is causing the problem unless it is kinked. I am therefore assuming that you mean in general that there is a fuel delivery problem.
You might have a vacuum leak, faulty MAF, weak fuel pump, DME on the verge of puking, idle air control valve malfunction, valves out of adjustment ...etc
A dirty fuel filter could have an effect but most likely would cause a consistent poor running behavior or a severe bog upon heavy load. If you have high mileage without ever having replaced the fuel filter, I would recommend it anyway. What have you done so far to diagnose the car?
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to
and register.. it's FREE
EXtech is offline
post #3 of 3 (permalink) Old 03-23-2004, 08:37 PM Thread Starter
found it out! i smelled the fuel from in the engine compartment so that narrowed it down, it was actually the rubber fuel line going from the T-bar to my fuel rail, so i replaced that and its allll better now, thanks!!
<img src='
The b0x that r0x
M5power is offline
Fuel Leak ajreich 3-Series (E36) 1 11-13-2005 08:00 AM
How to test fuel system pressure? babzenuda 3-Series (E21, E30) 4 01-13-2004 04:35 AM
fuel delivery system questions SeatTime 3-Series (E46, E90) 1 10-08-2003 08:29 AM
