Fuel Gauge Probs - BMW Forum - BimmerWerkz.com
Old 03-08-2005, 08:35 PM   #1 (permalink)
Man314's Avatar
Man314 is an unknown quantity at this point
Talking
Just brought home my 98 528i tonight! Pretty exciting as it is my first BMW! I had driven it two different times for ~30 miles prior to purchasing & everything seems to be in excellent working condition. Coming home tonight, I noticed fuel gage went from a little over 1/2 tank, down to 1/4 tank, then down to empty. No fuel is leaking. I shut the engine down & restarted & the fuel gauge goes back to 1/2 tank.
Prior to purchase, I had a mechanic check it out & all was good except it had an Instrument Cluster 09 Tank Level Sensor error code. Anyone heard of this fuel sensor going bad? Bad connection to instrument cluster? Any other ideas?
Man314 is offline   Reply With Quote
Old 03-08-2005, 09:20 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Ya sounds like it needs a fuel level sensor. Sensor problems are fairly common. There is 2 sensors 1 on each side of the tank. The fault should tell which 1 is acting up. If not then they would both need to be removed and sweep tested to see which is failing. It could be that both are having issues.
DT
DT
Recall On Fuel Gauge MaThGr82 3-Series (E46, E90) 1 10-17-2004 12:29 AM
Error message and fuel gauge ahraah 3-Series (E36) 2 08-07-2004 03:27 PM
E36 320 FAULTY FUEL GAUGE Markyb87 3-Series (E36) 5 05-24-2004 09:52 AM
Fuel Gauge Problem BeemerMan 3-Series (E36) 1 09-18-2003 07:22 PM
