Front Wheel Shimmy - BMW Forum - BimmerWerkz.com
post #1 of 7 (permalink) Old 03-11-2005, 12:40 PM Thread Starter
brians15 is an unknown quantity at this point
I have a '93 525 w/ 70k miles and notice a steering wheel and front end shimmy when i turn and hit a bump, not real bad but noticeable. Any ideas? Thanks.
brians15 is offline
post #2 of 7 (permalink) Old 03-11-2005, 01:37 PM
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
What do you mean by "shimmy" it it pulling, shaking, any noises?
[snapback]308922[/snapback]
tacroteau is offline
post #3 of 7 (permalink) Old 03-11-2005, 04:11 PM Thread Starter
Originally posted by tacroteau+Mar 11 2005, 01:37 PM--><div class='quotetop'>QUOTE(tacroteau @ Mar 11 2005, 01:37 PM)</div><div class='quotemain'>What do you mean by "shimmy" it it pulling, shaking, any noises?
<!--QuoteBegin-brians15
[snapback]308964[/snapback]
[/b][/quote]
No noises no pulling, just a wobble/shimmy thru the steering wheel.
brians15 is offline
post #4 of 7 (permalink) Old 03-12-2005, 01:14 AM
CosmosBlack's Avatar
CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute CosmosBlack has a reputation beyond repute
First thing to do would be to check visually for any damaged or bent parts....then wheel balancing.
And you go from there...
2012 Porsche 911 GTS
2008 Ford F150 Foose Edition
2010 VW Touareg
Gone...2002 Porsche 911 C4S
Gone...2000 BMW 540i
Gone...1995 BMW 540i
CosmosBlack is offline
post #5 of 7 (permalink) Old 03-12-2005, 12:19 PM
tacroteau's Avatar
Before you spend any money, try this jack up the nose of the car and try to rotate your tires side to side (as if you were trying to turn the steering wheel) There should be no play (or very very little). If you are able to "kick"it back and forth it looks like your rack has about had it. Then check for small power steering leaks, alond the back of your firewall under the hood.
Good luck
[snapback]309363[/snapback]
post #6 of 7 (permalink) Old 03-12-2005, 03:00 PM
Hoppy's535i's Avatar
Hoppy's535i is an unknown quantity at this point
if ballencing the tires doesnt help. thrust arm bushings.
<span style='font-size:11pt;line-height:100%'><span style='color:blue'> theres no replacement for displacement </span></span>
Hoppy's535i is offline
post #7 of 7 (permalink) Old 03-12-2005, 04:44 PM
while i guess it could be a rack it is more likely to be the lower control arms. if you are able to move the wheels (if they have a little play in the turing of the wheel) then it is probablly the lower ball joint that has failed. and the ball joint is integrated into thge lower control arm, and the whole control arm must be replaced.
one way to be sure that it is a bad rack would be to try and take the boot on the rack loose and if any fluid comes out then the rack has to be replaced. that may be a little more involved that you want to go. you could always take it to the dealer and they can get ya srtaightened out
bryan1970 is offline
Ahh..... The Age Old Question liltrig99 3-Series (E36) 11 08-04-2005 02:29 AM
Front Wheel Bearings wulley1 3-Series (E36) 4 05-15-2005 12:57 AM
Question On Front Wheel Bearings SuperFreaks 323is 3-Series (E36) 3 03-08-2005 03:07 PM
A Ghost in my front end... Name: Shimmy Spector mathetas 3-Series (E36) 3 08-27-2004 10:47 PM
Ghost Haunting Front End: Shimmy Spector mathetas 3-Series (E36) 1 08-26-2004 08:40 PM
