Front end shimmy while braking and hitting a bump - BMW Forum - BimmerWerkz.com
Old 07-07-2009, 10:53 AM   #1 (permalink)
Car: 2002 530i
tnations is on a distinguished road
The front suspension and steering wheel on my 2002 530i shimmy when I am braking and happen to hit a pot hole, rumble strip, etc. I have only noticed this at relatively low speeds.
tnations is offline   Reply With Quote
Old 07-07-2009, 11:08 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Both the E39 5 series and the E38 7-Series and other models can suffer from the dreaded 'shimmy'. This is wheel-wobble that usually first shows itself under braking, for instance, when coming off a motorway intersection and braking from high speed. The wobble can be felt through the steering-wheel but it usually disappears as the car speed reduces.
Sometimes this is all you ever get, but more usually you will start to get wobble as the car is accelerated through 50 - 60MPH. The more you drive the car the worse it will get. The wobble is quite often accompanied by tram lining and a general feeling of imprecision from the steering in general.
The shimmies are often an indication of general wear in the steering system and suspension, the BMW E38 & E39 and other models have a great deal of weight over the front wheels, especially when braking. It also seems to have a resonant frequency that occurs between 50 and 60 MPH, if there is any weakness it is at this speed where the problems will occur.
Wobbles that aren't shimmies
Let's first get rid of the wheel-wobble that isn't shimmy. If you get a wheel-wobble that really feels as if the wheel is coming loose and gets worse when the brakes are used then the first thing to suspect is a sticky brake calliper. The difference between shimmy and the wobble caused by a sticking brake calliper is that latter causes a massive wobble, the steering wheel is difficult to keep hold of and the wobble keeps going when you slow down, almost to a standstill.
Vibration that only shows itself when giving the car some welly, especially in 2nd and 3rd gear is quite often due to the propshaft centre bearing. The bearing is held in a rubber-enclosed housing. When the bearing starts to fail the rubber soon deteriorates and this allows the propshaft too much lateral movement. The movement causes a vibration through the car, it will eventually get to a point where the propshaft will start thumping the transmission tunnel. This type of problem always goes away when the throttle is lifted whereas shimmy doesn't.
Getting rid of the shimmies - the easy things
Wheels
The best place to start (and often the cheapest) is with the road wheels. The first thing to check is if the wheels are right for the car.
If you have fitted an alloy from a model with a different centre bore then you must fit spigot-rings. The only problem is that spigot-rings are not normally high-precision parts, they wear and corrode and when they do they will not hold the wheel central to the hub. If you are using spigot-rings consider getting alloys with the correct offset and bore, or, at the very least get new spigot rings.
Even if you are using standard wheels or are using wheels with the correct bore and offset it is worth cleaning the bore and mating surfaces on both the inside of the wheel and the hub. Where there is corrosion on the hub or wheel the wheel will not mate correctly with the hub.
Tyres
Cheap tyres are often a cause of problems, although these balance fine at low speeds, once they are taking the load of the car and are rotating at speed they do not retain their shape or were not round in the first place. There is only so much that sticking lead weights on the rim can compensate for. If you have a lot of lead on your wheels then something is not right in the first place. If you do not have staggered wheels fitted it is well worth rotating the wheels from the back to the front of the car to see if there is any difference. If it makes a big difference it is probably a problem with the tyres.
Getting rid of the shimmies - the harder bits
Once all the easy options are out of the way we have to move on to the front suspension components. There is a lot of advice given on what to change first but in my experience most problems are either removed entirely or at least made significantly better by replacing the upper arms and rubber bush.
While you are at it you might as well replace the lower arms as well , the cost is not all that high and is worth doing once the car is on the lift. A big difference can be made by just changing the bushes but normally if the bushes are damaged then the ball-joints are damaged at the same time. Some like to replace the bushes with polyurethane after-market versions, be aware though that this will significantly affect the quality of the ride and may well lead to other component failures. The bushes have to be pressed into the arms if you buy them separately.
Getting rid of shimmies - it's getting much harder now
We have now covered the possible causes in 95% of the cases I've been involved with. I have heard of miracle fixes where just one component of the front suspension has been replaced before the usual things have been tried but these are really just one-offs. So, in order of the most likely here are the remaining candidates:
Front stabiliser joints
Centre tie-rod , Drag link bearing and Tie rods
Once you have got to this point things have got pretty expensive. You can get complete suspension refurbishment kits from Ebay.de, I have never tried these but have heard good things about them. My present E38 735i had shimmy which was cured by replacing the centre tie rod. However, the giveaway for a centre tie rod failure is that they groan when the engine gets hot, and can be expensive!
Old 07-07-2009, 11:10 AM   #3 (permalink)
Kai
Kai's Avatar
Car: E39 Alpine White 528i, E34-Sold.
Kai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud ofKai has much to be proud of
Send a message via AIM to Kai
The front end bushings on my E34 caused the same problem, but it only happened between 60-65ish mph. I would give it a look at least if you can't figure out anything else to check. Hope you get the help you need.
Kai is offline   Reply With Quote
Old 07-08-2009, 10:50 PM   #4 (permalink)
Car: 91/BMW/535i
DonJ is on a distinguished road
I just bought a 1991 535i from a friend and it has 162,000 miles.
It shimmies when breaking. Prior to me buying it he replaced rotors and calipers and pads and it didn't fix the prolem. He took it to a mechanic and was told it is the thrust rod bushings - very common problem and these are the symptoms you experience.
Do a search for thrust rod bushings - you'll find a lot of info on how to replace.
I haven't had mine fixed yet - I'm battling a few other issues with the car right now.
DonJ is offline   Reply With Quote
Old 07-08-2009, 11:11 PM   #5 (permalink)
Mr. Clean
BimmerE39's Avatar
I had a similar problem on my E39. It was resolved with new upper and lower control arms. I also chose to have the Powerflex control arm bushings pressed in while I was at it and it took care of the problem.
Old 07-25-2009, 12:06 AM   #6 (permalink)
gitt is on a distinguished road
thank Marti5. very informative.
what about this issue:
This might have been discussed several times before, if yes it would be great if you can point me to the correct threads...
I noticed that my steering feel changes from time to time. Sometimes, the steering feels slightly disconnected and loose and at other times it feels precise and heavy (typical BMW feel). Whenever I drive or break on rough surfaces or bad roads, the steering moves left and right whenever the tires hit the rough patches on the road and I have to hold the steering tight to make the car go straight. Sometimes I feel that there's also a slight delay in the car responding when I turn my steering suddenly to the right or left.
I have read related threads with posts suggesting steering feedback. But I am not sure if the feedback is supposed to be so much that your steering shakes while going over rough surfaces or hitting a stone on the road... Does the steering feel vary based on surfaces? would balancing and alignment probably fix this?perhaps steering rack, camber, CA bushes, suspension...?
325ci 02/50k miles sports package
Tires: Michelin pilot sport dot oc 8a
225/45/r17
Pressure 32/38
gitt is offline   Reply With Quote
Old 07-28-2009, 09:23 PM   #7 (permalink)
Car: 92 E34, 99 E38 (goner), 90 E34
emiliomax is on a distinguished road
I've owned an E38 and currently own two E34. Both models are susceptible to thrust arm bushings wearing out. And the symptoms are about the same. I do believe your 325 has thrust arms also. So, you might want to look into that first. Like Marti said, also look at the condition of your tires.
emiliomax is offline   Reply With Quote
Old 07-28-2009, 11:38 PM   #8 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
In my case, I have replaced only the lower control arms. This has slightly improved the situation but the problem is not fully resolved. I did that before 4months / 20,000 KM when the inner side of the front tires was worn out due to this. Now I shall check out every thing again.
rashid is offline   Reply With Quote
Front end shimmy? DIRTE30 3-Series (E21, E30) 12 11-17-2006 11:47 PM
Front End Shimmy, Worse In Curves bkcraun 3-Series (E21, E30) 2 06-22-2005 09:30 PM
A Ghost in my front end... Name: Shimmy Spector mathetas 3-Series (E36) 3 08-27-2004 10:47 PM
1995 740il front end shimmy mike727 1,6,7,8 - Series and Mini Cooper 7 03-08-2004 11:10 PM
A Ghost in my front end... Name: Shimmy Spector mozart 3-Series (E21, E30) 0 12-31-1969 07:00 PM
