Flat spot while in First Gear - BMW Forum - BimmerWerkz.com
Old 06-20-2009, 02:30 AM   #1 (permalink)
alpine090 is on a distinguished road
Unhappy Flat spot while in First Gear
Hi Guys,
I have just had over £700 worth of work done on my 528i, and now the car is running fantastic apart from one problem that is really niggling me.
When i pull away in first for about a minute there is a loss of power and then the car picks up and is absolutely fine.
Is this a common problem or am i looking at another major bill coming up
Any Thoughts or ideas would be much appreciated.
alpine090 is offline   Reply With Quote
Old 06-20-2009, 06:21 AM   #2 (permalink)
graveshaker's Avatar
Car: Mine; 1998 Alpine white 540I/6 mods
graveshaker is on a distinguished road
Assuming you have a munual shift, you're experiencing clutch delay. BMW engineers installed a clutch delay valve (CDV) between the line directly before the slave cylinder. What this does is allow the same amount of pressure to engage the clutch no matter how hard you to shift. This was designed to detour shock to the drive train from novice drivers. The CDV can easily be removed in a matter of minutes with no addition parts or modifications. There are many DIYs explaining in detail on the removal. The only tools needed aside from ramps or jack stands are an 11mm crows foot wrench and a 14mm open end wrench. Once the CDV is removed and your traction control is turned off, your car will go through gears like a normal car would. I drive a 540i/6 and can chirp the wheels trough 3rd (not recommended) but good to no I can. PM me and I can explain the removal of the CDV without having to bleed the system. Took me 7 minutes flat.
graveshaker is offline   Reply With Quote
Run Flat Tires Make Your Wallet Run Flat IXLR8 1,6,7,8 - Series and Mini Cooper 1 05-21-2005 11:58 AM
Flat Spot On Diesels gareth 3-Series (E46, E90) 1 03-10-2005 08:09 AM
528i Flat Spot After New Turbo. rizla 5-Series (E12,E28, E34, E39, E60) 3 11-19-2004 03:48 PM
Flat Spot Verne 5-Series (E12,E28, E34, E39, E60) 7 04-21-2004 07:05 AM
E60 run flat tire is flat!!! Silver4evr 5-Series (E12,E28, E34, E39, E60) 16 04-13-2004 04:58 PM
