Fixed coolant tank and now car overheats - BMW Forum - BimmerWerkz.com
Old 08-15-2009, 06:22 PM   #1 (permalink)
E34freek is on a distinguished road
Angry Fixed coolant tank and now car overheats
Hi all I just fixed my coolant tank on my 1993 525i in the process i broke the bleeder and had to fill it wrong is there any other way to bleed the system? I really hope so because this is my daily driver.
E34freek is offline   Reply With Quote
Old 08-15-2009, 08:23 PM   #2 (permalink)
Have you tried the search feature? There are many threads on the bleeding of cooling systems.
Old 08-16-2009, 04:51 PM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
GoTTa Bleed friend. ain't no two ways about that. U can try bleeding by filling the reservoir to flowing full... loosening the top radiator hose clamp, and letting the coolant "bleed" awhile, and hope it will work. It will be messy!!!
bleeder screw are where they are (up high in the system) so air pockets can be purged.
Good luck ;-)
Old 08-17-2009, 03:42 PM   #4 (permalink)
BlueKnight is on a distinguished road
Please tell me you fixed. I had the same problem. Did not bleed properly.
2 blocks from home, needle on Red, trying to get over to the side of the road.
BOOOOOOM!!!!!! my plastic thermostat housing blew wide open!
Took possession of a '98 528i on May 12, 2009.
Still can't take the grin off my face!
BlueKnight is offline   Reply With Quote
Old 08-17-2009, 03:49 PM   #5 (permalink)
Arrow
BOOOOM!???... ummm. i suggest you have the car checked out. Check for water in oil... or oil in coolant. Unless the t-stat/t-stat housing was defective, for it go BOOOM tells me that engine compression is leaking into your cooling system. *sigh... i hate to be the bearer of bad news :-(
Either way, replace the part, bleed properly and let us see... with some luck it was just steam that did the t-stat housing in ;-) You will know if there's engine damage... rough idling sputtering, and the like. (I sure hope not)
Do a compression check on all cylinders, and while you are at it, check for traces of coolant in plugs.
Good Luck
Old 08-17-2009, 03:55 PM   #6 (permalink)
Originally Posted by darkhorse737 View Post
BOOOOM!???... ummm. i suggest you have the car checked out. Check for water in oil... or oil in coolant. Unless the bottle was defective, for it go BOOOM tells me that engine compression is leaking into your cooling system. *sigh... i hate to be the bearer of bad news :-(
Good Luck
I think I'm very lucky.
Two blocks from home, my mechanic is two blocks in the other direction.
No oil/coolant coolant/oil that is the first thing he checked.
I think that the 'stat must have been stuck. Or the BMW Gods were lookin' out for the newb.
Old 08-17-2009, 04:03 PM   #7 (permalink)
Thumbs up
Old 08-21-2009, 03:27 PM   #8 (permalink)
Thumbs up it is fixed
Hi guys sorry it took so long to reply. And to answer the questions yes it is fixed I went to my buddies junk yard and bought a radiator fan shroud and coolant bottle for $40. The build date on the rad is 9/16/08 and it is a factory replacement as well as the coolant bottle which is still the opaque white that they are when new. so all in all it wasn't bad and it only took 15 minutes to take out the old stuff and install the new. and after i bleed it i made sure the t stat worked as well. Thanks for your help to all.
Old 08-21-2009, 03:59 PM   #9 (permalink)
Glad to see it's sorted!
Coolant Reservoir Tank Powderhound X Series 11 01-23-2013 10:46 PM
car finally fixed! sy5alive 3-Series (E36) 2 09-16-2004 01:46 AM
Where is coolant tank? genghis56 3-Series (E36) 2 09-07-2004 02:01 PM
Help, Coolant tank leaking walt525tour 5-Series (E12,E28, E34, E39, E60) 9 08-26-2004 09:39 PM
