Fitting Driving/Fog lights to E34xM50 - BMW Forum - BimmerWerkz.com
Old 04-09-2006, 07:20 AM   #1 (permalink)
schematic is on a distinguished road
I've just purchased a set of Driving/fog lights from flea bay. what's involved in fitting these? Do I need another Loom/Relay/Switch or are they hidden away somewhere? I have had a Quick look underneath but could not see any wiring at the locations.
schematic is offline   Reply With Quote
Old 04-14-2006, 04:51 AM   #2 (permalink)
No Reply!! Driving/Fog lights Install
Well I've sussed out I need to put in a Loom for the Driving/Fog Lights and I'll have to change the original fog light switch as this only switches on one position (rear fog) not two. Does the other 2 way switch use the same wiring?? or do I need to run yet more wires?? I Know the Loom for the Lights plugs in on the Left hand side of the Engine compartment but surely it can't be that big a job to install and what Box is the relay for this hidden in??
Old 04-14-2006, 11:41 AM   #3 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
The 1 position fog light switch only switches the front foglights, not rear ...
If you wanted to use the 2 position switch, you would have to modify it because when it's in position 2, position 1 is also on ... so in turn if you wired the driving lights on pos. 2, your regular foglights would also come on when they are turned off ... I dunno if I'm making much sense, but you'd probably get pulled over for too much light unless you modify the switch to have independent turn on/off.
edit: remove the connection between the 2 positions, then run a relay that would switch foglights off when the driving lights come on and vice versa.
Old 04-19-2006, 03:39 PM   #4 (permalink)
As I have not had a lot of response on this subject I have been right through the system myself these are my findings on my car a 520i
The wires for the Front Driving/Fog lights are already in place but taped back in each front corner colours Yellow/Red and brown.
The 1 Position switch only switches the REAR Fog lights on and if you check the switch itself pin 1 the one that supplies switching to the front is not there so it must be changed for a 2 position switch to give you first position Front Drive/Fog lights and second position both front and rear Fog lights there is no need to modify this set up as this is the correct BMW set up.
In addition to this you have to plug in a Front Fog Light relay into the Front distribution box the fuses are already in place there is no relay for the rear fog lights so all I need to do now is find out the relay place for my Fog lights! but that is a simple matter of probing with my sparky Meter. I can't wait to start friving round with my fog lights on all the time as we do get a lot of sea fog down on the south coast of England.
Projectr Lights with Angel lights install HELP! BMerViXeN 3-Series (E36) 31 03-12-2006 09:54 PM
Corner Lights Not fitting properly bimmer_boy 3-Series (E36) 30 03-30-2004 02:34 AM
electrical of licence plate, rear side lights javieruz 3-Series (E21, E30) 1 03-14-2004 08:08 PM
Group Buy on e36 Euro crystal clear tail lights calm3 Classifieds Sell & Buy 13 04-26-2003 05:56 PM
