| Faulty Diesel Injectors -530d Hi all,
I'm new around here, and I feel like i'm begging for your help but I was wondering if anyone else has experienced problems like me.
When I first bought my car last year it was shaking on idle, small issue I thought, anyway turns out 5 of the 6 injectors all had an irregular spray pattern and needed to be replaced as they were so bad.
Now 1 year on the car is starting to shake again at idle, more in cold weather.
I have also noticed a ticking under acceleration which varies according to load/revs, possible connection?
Has anyone else had issues like this? I believe the new injectors should have a warranty so i'll see what can be done about the problem.
I'll keep you all informed.. |
