Fault Codes P0170,1073,P1188,P1189, Replaced all 4 O2's and Now only Getting P0170-73 - BMW Forum - BimmerWerkz.com
Old 05-24-2011, 12:19 AM   #1 (permalink)
romanfishin is on a distinguished road
I have been dealing with Fault Codes P0170,1073,P1188,P1189, Replaced all 4 O2's and Now only Getting P0170-P0173 only. I checked for Air and Vacuum leaks and dont think I have any, cleaned and checked MAF and is working ok. engine runs excellent and powerful, just need to fix the problem so i can get rid of the MIL and get the emissions passed. Car always had plugs replaced at 30-50k, always used mobile 1 fully synthetic 5-30, and last two changes 10-30. Any Advice greatly needed. Please.. I have a sport package 99 528i 217k
romanfishin is offline   Reply With Quote
Old 05-24-2011, 02:10 PM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Reset the computer !
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Old 05-24-2011, 05:38 PM   #3 (permalink)
Do you mean erase the fault codes with the code reader/scanner?
Old 05-25-2011, 01:48 PM   #4 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Worth a try if the car is fine !!
Eso es todo!
BMW Part Market
New Member ?
Old 05-25-2011, 02:44 PM   #5 (permalink)
Cool
I Reset the codes and the same codes come back, p0170,p0173, even the
p1188, and p1189 came back also. If anyone has any advice please share. Thanks.
Old 05-25-2011, 02:46 PM   #6 (permalink)
Can anyone give me the normal reading for the e39 Live data and ranges I should be getting on the car, im trying to figure out what else could be causing these codes.
Old 05-26-2011, 12:28 PM   #7 (permalink)
Please someone I need help to fix this problem.
Old 05-26-2011, 02:03 PM   #8 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
I maybe going off at a tangent here but maybe the injectors are fouling...
TBH it could be allsorts of minor things, but I'm on it !!
DAZ
Eso es todo!
BMW Part Market
New Member ?
Old 05-26-2011, 07:19 PM   #9 (permalink)
not sure what the ranges are for the MAF but according to bentley manual they should be around 0.5, sometimes im getting 0.63, 0.68, 0.76, at idle, when driving it goes 1.00 and above all the way past 3.0+, now i checked the air filter housing and boots and have noticed some cracks that have not penatrated the rubber in the boots, also i have noticed two holes on the bottom side wall of the filter houseing, but they look like vent holes that were not made from the plastic going bad, can anyone eleborate on this please.. Thanks Dabsy for helping. these codes are driving me nuts.. i have erased the codes again and now only p1188 and p1189 are coming on..
Trouble codes p0170 and p0135 CindyM 5-Series (E12,E28, E34, E39, E60) 15 07-08-2011 11:49 PM
E46 323i fuel trim P1188 and P1189 bavareze 3-Series (E46, E90) 5 04-06-2011 11:29 PM
Curing the P0170 and P0173 Codes cdrmhm New Members Check In 1 03-28-2011 10:23 PM
P0340 P1188 P1189 besian vanos seals indianolajohn 5-Series (E12,E28, E34, E39, E60) 3 03-29-2010 12:27 PM
Check Engine Fault Code P1188 little jack 3-Series (E36) 6 10-30-2008 06:32 PM
