Fast Idling - BMW Forum - BimmerWerkz.com
Old 06-22-2004, 12:36 PM   #1 (permalink)
JCooper60 is an unknown quantity at this point
My idling speed is 1500 rpms once my engine warms up. Are there any other causes besides the slider valve or idle control unit ?
JCooper60 is offline   Reply With Quote
Old 06-22-2004, 12:50 PM   #2 (permalink)
Millions of them.
Torque's Avatar
Car: e36 w/ a m42
might be a bad ECU (engine control unit) if nothing else works for it.
Old 06-22-2004, 01:22 PM   #3 (permalink)
silverlea is an unknown quantity at this point
The problem could possibly be associated with the auto choke not switching off once engine is warm, thats if your car has that setup on it ? Is the return spring on the throttle adjusted correctly ?
Hope this helps.
Chers,
Silverlea.
silverlea is offline   Reply With Quote
Old 06-23-2004, 12:58 PM   #4 (permalink)
ronskal is an unknown quantity at this point
OK, I have the Bentley Manual here and it says the idle speed is via the Idle Speed Control Unit and Idle Air Stabilizing Valve. So I think your on the right path.
The ISCU has multiple inputs such as: coolant temp., air temp., engine speed etc.
If for instance the coolant temp. wire to the ISCU is loose the unit might think the engine is not warmed up, or the sensor could be faulty.
Idle speed is not a function of the main computer.
If you have a manual, you'll be able to go through the steps. If no manual it would be very hard to find the problem if it was'nt something obvious.
02 GMC Yukon SLT 5.3
02 Ninja ZX9R
ronskal is offline   Reply With Quote
Old 06-25-2004, 03:53 PM   #5 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
Check your throttle body. You might be able to adjust the linkage to make it idle a little lower.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
85 318i how fast ? j123crx 3-Series (E21, E30) 0 09-22-2005 08:27 PM
Unstable Idling On 'd' 94 325is wango 3-Series (E36) 6 09-01-2005 02:42 AM
Shorting in a fuse for guages, and other idling. M5power 5-Series (E12,E28, E34, E39, E60) 0 04-10-2004 11:35 PM
Driving at the Track SpeedsterBMW 3-Series (E46, E90) 18 08-19-2003 04:20 PM
