» Sponsors
» Sponsors
Old 08-07-2008, 09:30 PM   #1 (permalink)
PKulak7's Avatar
Photos: 0
PKulak7 is on a distinguished road
Fan won't turn off, 530 i
I just recently bought a 2001 530 i, my fan won't turn off. I have disconnected the battery but I can't do that forever. Has anyone ever had this issue?
PKulak7 is offline   Reply With Quote
Old 08-07-2008, 11:19 PM   #2 (permalink)
Moderator
Dirty_Tool's Avatar
Photos: 0
which fan? interior blower fan? if so do a search on final stage unit and im sure you will yield several results with all the info you need.
DT
Old 08-08-2008, 05:41 PM   #3 (permalink)
PKulak7's Avatar
Photos: 0
what is the final stage unit? could this also be the new resistor and how do you know?
Old 08-08-2008, 11:44 PM   #4 (permalink)
Photos: 0
RAMRJAMR is on a distinguished road
Final Stage Unit
Just had the same problem with my 2002 525i. Very simple fix it would seem, but it cost about $300 or so with labor. I'm not sure what's involved with changing it yourself so I can't advise you on that. The part number for my car is 64116923204 and has a BMW Catalog price of $88.16 but I think the dealership charged me a hundred and something. If you can change it yourself, should be a relatively inexpensive fix.
You should check out this site for part numbers and diagrams. Just put in the "last 7" of your VIN and you can get all the part information for your car.
RealOEM.COM * Online BMW Parts Catalog
Good luck.
RAMRJAMR is offline   Reply With Quote
Old 09-08-2008, 07:56 PM   #5 (permalink)
Photos: 0
jiigar is on a distinguished road
I have the same problem, My AUX fan stays on and its on full blast as soon as I plug it in with no intentions of slowing down or stopping even 45 min after the car has been shut off.
I can plug it in with the engine cold and the fan goes full speed.
The outside temp gauge reads -40Deg F ( sensor must be knocked of or something) that has nothing to do with it right?
The engine temp stays at 12 clock at all times
jiigar is offline   Reply With Quote
Old 09-13-2008, 02:49 AM   #6 (permalink)
Car: 03Suburban!/ 99 323
Photos: 0
toml is on a distinguished road
Maybe its just me guys but hold on
dirty tool's question was WHICH FAN DO YOU MEAN??
AUXILIARY COOLING FAN FOR ENGINE at radiator?
OR
Interior heater/air conditioner fan (often called blower)
(this is the one with the "final stage resistor" problem/fix)
let make certain we are all on the same page
OP .. which fan please?
toml is offline   Reply With Quote
Old 09-15-2008, 07:39 AM   #7 (permalink)
Photos: 0
bwatters is on a distinguished road
I have a similar problem with my 2001 530i. Mine is intermittent. I replaced the aux fan in July because it had a burned out motor. Now, about 50% of the time it continues to run after turning off the engine. It continues to run until I unplug it at the connector mounted to the shroud. Sometimes it will run on high speed immediately after I start the cold engine. Yesterday it did a very interesting thing. The car had been sitting for half the day in a parking lot. As I approached the car I hit to button on the key to unlock the door. As I pressed the button the lights blinked to little beep sounded and the fan started to run. What do you think about that? So how about some trouble shooting advice? I'm stumped.
bwatters is offline   Reply With Quote
Old 10-10-2008, 12:34 PM   #8 (permalink)
emzet's Avatar
Car: 2000/BMW/528IT
Photos: 0
emzet is on a distinguished road
Is there a set of instructions on how to replace the final stage unit on e39 available somewere on the net? Thanks
emzet is offline   Reply With Quote
Old 10-10-2008, 12:55 PM   #9 (permalink)
emzet's Avatar
Car: 2000/BMW/528IT
Photos: 0
OK, to anwer my own question, here is what I found on replacing the unit:
DIY - Replacing the final stage unit/blower motor resistor - bimmerfest - BMW Forums
www.540i6.com - Final Stage Unit Replacement
vB code is On
Any suggestions on how i broke my fan shroud,fan, and radaitor? TUKRS-E46 3-Series (E46, E90) 3 02-13-2006 03:19 AM
Aux Fan Won't Turn Off!! fredo328 3-Series (E36) 9 06-05-2005 08:54 AM
Auxilary Fan (won't Turn On) / R-145a vmelikRUS 3-Series (E36) 6 05-03-2005 10:41 AM
Not A Big Fan Of My E39's Fan tacroteau 5-Series (E12,E28, E34, E39, E60) 3 04-19-2005 07:05 AM
Is the E36 Aux fan the same as the M44 engine fan? Autotechnica 3-Series (E36) 1 04-22-2004 03:37 PM
