Exhaust Adjustment - BMW Forum - BimmerWerkz.com
Old 11-03-2004, 02:10 PM   #1 (permalink)
dberger's Avatar
dberger is an unknown quantity at this point
Thumbs up
When I bought my 98 528i, the dealer that inspected it said that the catalytic converter was improperly mounted. It (or part of the exhaust ) is touching the cross member and causing a rattle noise. What can I expect to pay to have this fixed? re-mount? or just add a hanger? please any thoughts would help.
dberger
dberger is offline   Reply With Quote
Old 11-03-2004, 03:07 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
well it depends on what it is... if its really just an adjustment than you can do it yourself.
Old 11-03-2004, 03:17 PM   #3 (permalink)
billB's Avatar
AND/OR muffler place i.e. Midas
Old 11-04-2004, 02:35 AM   #4 (permalink)
BeelZibub is an unknown quantity at this point
Do you people really buy cars from dealers knowing there is a problem with it??? Jesus, he even pointed it out to you. I wouldn't even consider buying a car without it having just been fully serviced & MOT'd.
At the end of the day if it has the proper exhaust on it there shouldn't be a major problem. Although inproperly mounted could mean it has been fitted into the system in the wrong position OR just that a mounting bush has dropped off/not been fitted. Either way it's not a major problem BUT one the seller would usually take care of it before selling - I hope you got a good discount. Really you need to get her on a ramp/axle stands and have a proper look to see what's goin on. Or take her to an exhaust fitter and he should be able to sort it out in minutes.
BeelZibub is offline   Reply With Quote
Old 11-04-2004, 06:53 AM   #5 (permalink)
billB's Avatar
I am assuming AFTER you bought the car from somewhere else; you took it to the dealer for inspection. Yes?
Old 11-04-2004, 08:30 AM   #6 (permalink)
dberger's Avatar
Yes, I had it checked out after I bought it. I bought it from TX having saved about $3000.00 compared to the same car here ( Minneapolis MN ), Paid $15,000 for a 1998 528i sport with 65000 miles.
thanks for the advice.
Old 11-04-2004, 11:56 AM   #7 (permalink)
[snapback]224286[/snapback]
Sorry that I got the wrong end of the stick.
Once you get her a little bit higher look for the bit that is scraping/knocking and make sure there is no excessive wear. Look around the cat and the boxes to see if there is a mount point (basically a peice of metal rod welded to the box/tube) which is not pushed into a rubber mount. If all mounts are present and good It's more likely the system was assembled wrongly by a dodgy exhaust fitter and will need to be taken to pieces and put back together in the right way - arm yourself with a wrench set and some exhaust paste or as I said pop it into a fitter.
Another problem may be that a cheap PATTERN part has been fitted - these do not always fit the same as manufacturers parts - hope this isn't the case for you.
Old 11-04-2004, 11:57 AM   #8 (permalink)
billB's Avatar
I figured that!!
Old 11-04-2004, 01:52 PM   #9 (permalink)
dberger's Avatar
I brought it to Car X today and they said the exhaust was alll original, buy part was laying on the cross member, he heated part of the pipe up to realign, no more rattles. Cost =$60.00
thanks for the replys
Old 11-04-2004, 03:41 PM   #10 (permalink)
billB's Avatar
Glad to hear it and enjoy. Cheers
billb
Old 11-05-2004, 04:49 PM   #11 (permalink)
Glad she's sorted, but sounds like a dodgy fitting job in the first place. Nevermind though I guess the important thing is she's alright now!
Need Help!1987 325es: Exhaust Leak/runscrappy pettas 3-Series (E21, E30) 12 12-11-2004 05:12 AM
If Your Looking For A New Exhaust For A 328i... RDM3 Classifieds Sell & Buy 0 11-23-2004 04:07 PM
Fs Fk Automotive Exhaust For E36 328i New RDM3 Classifieds Sell & Buy 0 11-23-2004 04:06 PM
Ticketed for loud exhaust in California? Silver4evr Bimmer Talk/Motorsports Talk 0 06-23-2004 04:03 PM
