Error code "F0" Misfire detected on cylinder #3 - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 08-01-2006, 05:27 PM Thread Starter
Sugarmel is an unknown quantity at this point
I switched the plug and ignition coil on cylinder three with cylinder four. I still get the misfire detected on cylinder three. What can be causing this.
Sugarmel is offline
post #2 of 5 (permalink) Old 08-01-2006, 05:29 PM
Eric S.'s Avatar
Eric S. is on a distinguished road
Model? Year? Engine? Anything?
<span style='color
urple'>Eric S.</span>
2006 Honda Odyssey EXL-RES
Eric S. is offline
post #3 of 5 (permalink) Old 08-01-2006, 05:36 PM Thread Starter
It's a 1997 528I.
Sugarmel is offline
post #4 of 5 (permalink) Old 08-01-2006, 06:04 PM
LOS
LOS's Avatar
Eric, is it possible he needs to clear the code first and then try it again?
I'm saying clear the code first, switch the plug/coil and try it. Maybe he left the old code there??
If I'm not mistaken, codes are stored until clear.
LOS
LOS is offline
post #5 of 5 (permalink) Old 08-01-2006, 06:47 PM
Eric S.'s Avatar
LOS
Thanks for the vote of confidence but I am not up on how check-engine-lights behave. I have a Peake tool and I use that to clear them when in doubt. Don't know what to tell you if it isn't easy to clear the codes.
One thing I DO know is that just because the CEL doesn't come right back on after you reset it doesn't mean the problem is fixed. I believe it takes about 20 minutes of an out-of-tolerance condition to trigger the light, and all may seem OK until then.
<span style='color
Eric S. is offline
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 02:48 PM
Cylinder 3 Misfire, Related To Air Mass Meter? jasonharlos 3-Series (E46, E90) 8 10-06-2009 11:13 AM
Misfire Detected Cyl #5 328I99E46 3-Series (E46, E90) 1 04-17-2005 11:22 PM
Misfire Cylinder 5 gthoman 3-Series (E46, E90) 19 02-23-2005 03:07 PM
Misfire cylinder 1 Mrcapitan 3-Series (E36) 4 04-11-2004 04:28 PM
