Erratic idle 523i Auto E39 - BMW Forum - BimmerWerkz.com
Old 05-14-2008, 11:05 AM   #1 (permalink)
DuncanThomas is an unknown quantity at this point
I hope you can help
My car BMW 523i has not got an erratic idle.
Before I really stick my head under the bonnet I thought I would ask for help
The symptoms are:
When revs drop to idle sometime it nearly stalls or very lumpy 9around 200rpm
This can be rectified (most of the time by blipping the throttle) – not always easy with an automatic
When it happens there seems to be a sucking noise from under inlet manifold (black) under the + point should I be jump starting the car
(sorry not that technical) but always willing to learn and get hands dirty
Other than that it seems to run fine
Any pointers for me when I get my head under the bonnet and what should I look for
Thanks in advance
DuncanThomas is offline   Reply With Quote
Old 05-14-2008, 11:17 AM   #2 (permalink)
M3Nate08 is on a distinguished road
Sorry man I don't know about that one
M3Nate08 is offline   Reply With Quote
Old 06-08-2008, 12:07 AM   #3 (permalink)
Bimmer M.D.'s Avatar
Car: Calypso E36: HID/A.E/6000K/18" Rims
Bimmer M.D. is on a distinguished road
Please give more details, and be more specific.
** FOR SALE NOW! ** 1 Day Left! ** Click Picture! **
Bimmer M.D. is offline   Reply With Quote
Old 06-08-2008, 10:40 AM   #4 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
sucking noise you hear is indicative of an intake leak.
look under you hood and check your intake hoses for obvious cracking. In case, you can't see any visible signs, easiest way is to use a can of brake cleaner to aid you in your quest for finding the leak. spray around the intake area - AFM, rubber parts, especially where rubber joins to metal.
while you do that, notice the change in idle while you spray. There will be a marked change in idle the moment the brake cleaner soultion touches the break/crack
Old 06-19-2008, 11:08 AM   #5 (permalink)
p528I is on a distinguished road
Dont know about the sucking sounds but its displaying signs of a dodgy vanos system. Google 'vanos problems' to find out more info
p528I is offline   Reply With Quote
E39 523i se, heater problem ??? rxkevco 5-Series (E12,E28, E34, E39, E60) 1 01-13-2007 10:56 AM
Erratic Idle Fix snoopy325e 3-Series (E21, E30) 4 04-17-2005 06:27 AM
UK - 1997 Preg 523i SE (E39) For Sale NickC Classifieds Sell & Buy 0 05-30-2004 11:32 AM
UK Spec '97 E39 523i SE A/C - Compressor Make? NickC 5-Series (E12,E28, E34, E39, E60) 0 05-04-2004 09:50 AM
