Erratic heater blower - BMW Forum - BimmerWerkz.com
Old 11-22-2003, 08:37 AM   #1 (permalink)
mannyellis is an unknown quantity at this point
Hi all,
I have an E39 with an erratic heater blower problem. Has anyone had similar problems, and if so how do you fix it?
Cheers in advance.....
mannyellis is offline   Reply With Quote
Old 11-22-2003, 10:53 AM   #2 (permalink)
alanh's Avatar
alanh is an unknown quantity at this point
Send a message via AIM to alanh
more specific plz
Self-Proclaimed Genius
alanh is offline   Reply With Quote
Old 11-22-2003, 10:46 PM   #3 (permalink)
Hi alanh,
The heater blower intermitantly increases in speed, sometimes upto full power whether it's in auto or not. And I have no control over it apart from turning the blower off.
Old 11-24-2003, 04:59 AM   #4 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
isnt that supposed to happen when you turn the climate control to 32? it keeps the car at the same temp at all times ?
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 11-24-2003, 08:34 PM   #5 (permalink)
Quite possibly. But this happens ant any temperature.
Old 01-07-2004, 11:40 AM   #6 (permalink)
Nikk is an unknown quantity at this point
Hi
I have the same problem. You should be able to turn off 'auto' and reduce the blower level to the minimum without the climate control taking over as far as I know and when I do this, I get the same symptoms as you. I'm wondering whether this could just be loose connections as my fans tend to cut out for a short time when I hit a bump in the road. I'm having it serviced by a dealer in the next couple of weeks so will see if they can advise.
Nikk is offline   Reply With Quote
Old 01-08-2004, 03:08 AM   #7 (permalink)
Cheers Nick,
Please keep me posted.
Old 01-23-2004, 11:36 AM   #8 (permalink)
Just had the car serviced at the dealer and, as predicted by other posts on the board, it was a faulty sensor (Apparently happens quite a bit. The part was £50 + fitting so not a cheap fix, but certainly cheaper than a new climate control unit. If you need the full name of the unit, let me know and I'll dig out the docs.
Cheers
Old 01-24-2004, 01:27 AM   #9 (permalink)
TECH's Avatar
They probably replaced the blower RESISTOR/FINAL STAGE UNIT. It's not a sensor.
Need help my heater blower is dead! crazy4396063 3-Series (E36) 1 10-30-2005 01:32 PM
Need Help! Problem With Blower, Heater. DiRay 3-Series (E21, E30) 4 02-15-2005 04:13 PM
Erratic a/c & heater fan E46 enterprise 3-Series (E46, E90) 3 12-02-2004 05:26 PM
1991 525i Air Conditioner / Heater Blower tvanderh 5-Series (E12,E28, E34, E39, E60) 1 08-21-2004 09:26 PM
Heater Blower Problem mozzo 3-Series (E36) 0 05-06-2004 05:52 AM
