Engine start problem - e39 - BMW Forum - BimmerWerkz.com
Old 05-17-2010, 04:54 AM   #1 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
I have an e39, 530 – 2002 with 386,000KM.
From time to time, I face difficulty to start the engine & the RPM will drop for few times before it fires & when I shift to D, it will drop again. Any thoughts or ideas?
rashid is offline   Reply With Quote
Old 05-17-2010, 02:59 PM   #2 (permalink)
Car: BMW E39 525 TDS SE '96
r1bby is on a distinguished road
Depends on your engine (petrol diesel) etc..
You could try taking it to a garage for a proper diagnostic.
Or you could could buy yourself a Haynes manual and try checking the battery power, terminal connections, defective starter solenoid or switch , starter motor, air filter dirty or clogged, ignition components damp, spark plugs, etc, etc, etc...
Hell when was the last time it was serviced?
Good luck!
r1bby is offline   Reply With Quote
Old 05-17-2010, 08:25 PM   #3 (permalink)
roma's Avatar
roma is on a distinguished road
did the check engen light come on? yes ,check the code,maybe misfire,intake elbow,gas filter,02 sensor check all this and you shuld be fine ...good luck
roma is offline   Reply With Quote
Old 05-18-2010, 12:27 AM   #4 (permalink)
I have petrol engine
1.The battery is ok.
2.Starter is also ok
3.Air filter dirty is cleaned & ok
4.Spark plugs are new & ok
5.Check engine light is not coming on - ok
6.Gas filter is new – ok
7.O2 sensor – what are the symptoms for faulty O2 sensor?
Old 05-18-2010, 09:20 PM   #5 (permalink)
roma's Avatar
even if the light is not on the code should be stored and check MAF
Old 05-18-2010, 11:07 PM   #6 (permalink)
ok, how to read the codes? any external tool is required?
Old 06-03-2010, 08:35 AM   #7 (permalink)
Turned out to be the CAM-SHAFT sensor. Replaced & 200$ (including labor) & it works fine now.
Old 06-03-2010, 09:26 AM   #8 (permalink)
Very glad it's sorted!
1991 E34 Engine wont start after engine swap pegasusflash 5-Series (E12,E28, E34, E39, E60) 7 12-09-2009 06:13 AM
E39...Problem with a "valve" in engine... iielighii 5-Series (E12,E28, E34, E39, E60) 4 08-25-2009 10:28 PM
02' 325 Engine Start Problem checho 3-Series (E46, E90) 2 05-09-2009 09:09 AM
e39 530d warm start problem NiTrO 5-Series (E12,E28, E34, E39, E60) 1 01-03-2007 04:11 AM
Engine Ping When First Start Engine Cold mikes325is 3-Series (E36) 0 09-29-2004 06:12 PM
