Engine Overheating/Cold air from Heater - BMW Forum - BimmerWerkz.com
Old 11-25-2003, 03:17 AM   #1 (permalink)
Bluebonnet is an unknown quantity at this point
1995, 85k miles, auto trans 525i: Temp gauge redlined on wife. I drove it home suspecting thermostat failure and thought I broke it loose. Replaced theromstat. Problem continued. Heater not working properly. Left mech-shop after replaceing radiator and temp gauge redlined @ 80 mph. Just prior to redline, heater started blowing cool air into cabin.
WASSUP?
Bluebonnet is offline   Reply With Quote
Old 11-25-2003, 08:27 AM   #2 (permalink)
lwebb12's Avatar
Car: 2000 M5
lwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond reputelwebb12 has a reputation beyond repute
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
your heater core may be broken internally. which would cause a problem keeping the coolant pressurized. it would need to be changed
Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
lwebb12 is offline   Reply With Quote
Old 11-25-2003, 09:24 AM   #3 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
lwebbs on the right path.. could very well be the core. do your windows fog up at all when the cars on?
if not then open your rad i bet your low on coolant or someone from the shop carlessly forgot to put enough antifreeze in the car.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 11-26-2003, 03:30 AM   #4 (permalink)
I took it back to the shop this morning. Technician suspects the thermostat wasn't installed properly. His plan for today is:
1. Verify thermostat installation
2. Verify system pressure level constant - bleed off air
3. Verify the impeller of h20 pump is functional.
Wish me luck.
Old 11-26-2003, 08:23 AM   #5 (permalink)
CBA
CBA's Avatar
good luck
-Founder
Old 11-26-2003, 08:35 AM   #6 (permalink)
mobtek520i's Avatar
mobtek520i is an unknown quantity at this point
how did it go blue?
w00t (30)
- Spank my muffin!
mobtek520i is offline   Reply With Quote
Old 12-17-2003, 06:41 PM   #7 (permalink)
E28boi's Avatar
E28boi is an unknown quantity at this point
If you are not losing coolant, check the heater valve. This is often overlooked. It can cause overheating if it malfunctions. This will also give you no heat in the car.
86 535i
99 Passat V6
E28boi is offline   Reply With Quote
Engine Temp Drops When Heater Is Turned On wulley1 3-Series (E36) 19 11-25-2007 10:55 AM
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Bad Engine Idle And Fault Not Found.. Paraklas 3-Series (E21, E30) 10 06-16-2005 09:25 PM
