| sounds like you are losing fuel and or spark for some particular reason. I would check, re-check and double check the coolant temp sensor and switch on the thermostat housing. Make sure they are also plugged in correctly to each respective sensor. Also look for major air leaks. Work around the basics. There are alot of possibilities. Good luck
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to http://206.123.107.13/stett and register.. it's FREE |
