emergency e34 wont start! - BMW Forum - BimmerWerkz.com
Old 08-19-2009, 12:59 PM   #1 (permalink)
Car: 1991 525i e34
blalockbmw is on a distinguished road
my 91 e34 started out this morning with a rough idle. It would fall below 1000 rpms then jump up to normal again. it would do it at red lights as well. I made it to work now it will not stay running. the car will start for a second then die. it has a strong gas odor as well. any ideas im stranded. icv maybe?
blalockbmw is offline   Reply With Quote
Old 08-19-2009, 01:08 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
easy things first. check air filter(replace as necessary)
clean out MAF - brake cleaner will suffice
if u can access the throttle body, clean that out as well;
then yes, ICV (can be cleaned out with brake cleaner as well)
Good luck
Old 08-19-2009, 01:34 PM   #3 (permalink)
Car: 1991 525i e34
ive got some engine degreaser will that work? thanks for the advice. the air filter is new the only thing that puzzels me is the strong gas odor like its flooding out or smng
Old 08-19-2009, 01:40 PM   #4 (permalink)
Lightbulb
engine degreaser... NO.
brake cleaner, carb cleaner, or MAF sensor cleaner only, follow it up with compressed air will be a nice touch if available.
strong gas smell. is an indication of lack of air to engine... or engine flooding.
if it still gives you probs. pull out 1 plug and tell me the condition.
black? wet? dry?
Old 08-19-2009, 01:42 PM   #5 (permalink)
Car: 1991 525i e34
k tanks again man i appreciate it. ill follow up i get off work around 6 so i cant do anything till then. its pouring rain to boot!
Old 08-19-2009, 03:16 PM   #6 (permalink)
Car: 1991 525i e34
cleaned it all out on my lunch break and shes purrin like a kitten. haha saved me about $180. Thanks man I will pass on the favor for sure
Old 08-19-2009, 03:38 PM   #7 (permalink)
Talking
Cheers!
Old 08-19-2009, 09:20 PM   #8 (permalink)
Car: 1991 525i e34
well it lost all power and is backfiring now. I have no idea what it could be
Old 08-20-2009, 02:03 AM   #9 (permalink)
Arrow
recheck your work.
Pay especially close attention to the connectors that you pulled when you took the parts down for cleaning.
make sure the air boots fir properly and clamped on tight so there are no air leaks.
if after that you still have probs. pull out a couple spark plugs 1 & 4 or 2 & 5... describe to me the condition.
wet? dry?
color.....of plugs.
let me know...
Old 08-21-2009, 02:39 PM   #10 (permalink)
Car: 1991 525i e34
Finally had time to pull the plugs and they were deff. the prob they looked like they had been in the car for at least 100k and they were the cheapest thing on the market. They were black and 2 had no gap left.
Old 08-21-2009, 03:15 PM   #11 (permalink)
Talking
you know what to do
95 M3 Wont Start!! crossmover03 3-Series (E36) 2 11-16-2008 05:20 PM
wont start. help! alexus16 3-Series (E46, E90) 1 09-27-2008 10:38 PM
95 318ic wont start, egine wont turn over. (couple cold days) vic318ic 3-Series (E36) 2 02-05-2007 10:00 AM
Wont start linx76 5-Series (E12,E28, E34, E39, E60) 4 01-27-2004 03:03 PM
