Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 04-12-2006, 01:58 PM   #1 (permalink)
Photos: 0
aero104 is on a distinguished road
Electrical question of the year...(help!)
I am trying to help a friend work out some VERY intreresting electrical gremlins from his 1993 525i touring wagon Automatic.
Below is some of the gremlins (that have been getting worse):
1. placing car in Reverse causes either trunk or rear glass to actuate open.
2. bumps in road sometimes cause either trunk or rear glass to actuate open
3. door locks/windows/cental locking sometimes doesn't work (all)
4. sometimes windshield wipers go on high but opening drivers door stops them :-) <---getting fun now?
5. sunroof will close be not open
6. reverse lights sometimes stay on all the time
7. rear glass electrical opening switch doesn't open window
8. rear hatch electrical latch does work
So here's what I have done so far:
1. checked all fuses (front and rear) ok
2. Checked main grounds (front left quarter panel, under rear seat, battery) ok
3. ohmed rear hatch and window switches ok
4. 12v power to rear main latch ok
5. no power to rear glass latch (but works if supply power from other latch)
6. gremlins disappear when removing one or both large "general relay modules" under rear seat??
7. ohmed wires from trunk to rear power panel ok
8. note: leaving car off for 15-20min then turning on key sometimes causes most everything to work normal, then with 10sec or so, things start faulting.
I'm guessing relay box X332 and X255 ?
Any ideas would be really helpful...
Thanks,
Aero104
aero104 is offline   Reply With Quote
Old 04-12-2006, 02:41 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Photos: 0
Call a priest.
1995 E38 740iL. Highly modded. Faster than you.
Lindsay fan club member.
Old 04-12-2006, 03:10 PM   #3 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Photos: 0
it seems as though there is a bad/loose ground somewhere in the car, from the discription of many things that have been happening....I would deffinatly inspect grounds (not just main grounds) be checking for loose grounds as well as the obvious...
Come see me at MySpace
Old 04-14-2006, 02:21 AM   #4 (permalink)
CosmosBlack's Avatar
Car: 2002 Porsche C4S
Photos: 0
I say you should check the fusible link by the battery terminals.
It could very possibly be cracked, worn or broken causing intermittent/occasional loss of contact.
Common E34 problem.
Old 04-14-2006, 04:48 AM   #5 (permalink)
To the left ...
Torque's Avatar
Car: '90 535im
Photos: 0
Send a message via AIM to Torque Send a message via MSN to Torque
Common E34 problem.
You beat me to it. My car was giving a lot of the same signs when it had a cracked fusible link.
Old 04-15-2006, 01:15 AM   #6 (permalink)
Photos: 0
Great Minds Think Alike.....
vB code is On
Electrical Problems And Other Newbie Questions 325eXTATIC 3-Series (E21, E30) 4 03-31-2005 10:35 AM
X5 Electrical Gremlins Year 2001 bradvo 6,7,8,X,Z - Series and Mini Cooper 3 12-21-2004 10:11 PM
Electrical question leibniz 3-Series (E36) 6 04-19-2004 01:15 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
