Electric tuning M51TDS - BMW Forum - BimmerWerkz.com
Old 04-02-2009, 12:12 PM   #1 (permalink)
Fockewulf is on a distinguished road
Question Electric tuning M51TDS
Hi.
My name is Feodor. I from Kazakhstan.
At me here such question:
Who was engaged in engine M51 E34 525 TDS tuning? The electric part interests.
WITHOUT change in software DDE.
I read about "electric" tuning at Belarus forum of the BMW. "Terminators" in DDE are disconnected. Joins the button in salon when it is necessary. Capacity increases to 180.p.s
There are at whom ideas on this theme? Can did the such? smile
Fockewulf is offline   Reply With Quote
Old 04-02-2009, 12:19 PM   #2 (permalink)
If by terminator you mean the rev limiter, there would be no point in doing that with no changes in the main software. And it would not increase output at all.
Old 04-02-2009, 12:32 PM   #3 (permalink)
Idea just in that to remove factory terminators in DDE. Which are responsible for ecology of emissions. It becomes not on always and when it is necessary.
The button in salon. Has pressed-180 p.s Has switched again - standard 143
Alteration only in DDE the small.
Old 04-02-2009, 12:47 PM   #4 (permalink)
Well that seems like something that might work. Have you a chance to get a demonstration ride in a car that has it?
Old 04-02-2009, 12:54 PM   #5 (permalink)
It do in Russia, I live in Kazakhstan...
Here I also ask YOU are engaged in it??? Can you to me will help?
Old 04-02-2009, 01:09 PM   #6 (permalink)
As much help as I can; here in the US, we have very few diesels. There is almost no diesel tuning done here at all.
Old 04-02-2009, 01:17 PM   #7 (permalink)
Clearly.
At us here on the contrary. The People such. All needs to be improved
Old 04-02-2009, 02:50 PM   #8 (permalink)
Remember that when you boost performance, you will see a big increase in fuel consumption.
Old 04-03-2009, 02:39 PM   #9 (permalink)
MADDOUG is on a distinguished road
YouTube - BMW 525 TDS E39 CHIP 0-100 SVO plenty of these vids on 'you tube' showing performance attained,all good but remember the enemy of the e34 tds is heat,the cooling system must be in top order or the engine will over heat and expire in very short order.Most chip tuning in uk involves either a remap or a box that plugs in wiring from injector pump and alters ecu signals to give desired results.In normal everyday driving mpg is actually better by around 20% over stock.
MADDOUG is offline   Reply With Quote
Old 04-04-2009, 10:50 AM   #10 (permalink)
Cool
The chip is unnecessary me... What for?
I need another. Without software change!!!!
Old 04-04-2009, 11:54 AM   #11 (permalink)
I think what you are looking for is an emissions control bypass, operated by an in car switch.
Old 04-04-2009, 12:05 PM   #12 (permalink)
Yes yes it is exact!!!! Who me has understood that. Can help with this question?
Old 04-04-2009, 12:52 PM   #13 (permalink)
Smile
At replacement of the software the engine works constantly in the forced mode. The raised expense of fuel, deterioration of the engine...
To include the button when it is necessary it is the best variant.
I know that it is necessary to solder in the resistor 7-10 kOm in block DDE. But the exact scheme at me is not present... Therefore I ask the help. There Can be who knows the exact scheme.
Old 04-04-2009, 01:10 PM   #14 (permalink)
I'm curious about this, so I'll look around and see what I can find out.
Old 04-04-2009, 01:15 PM   #15 (permalink)
Thanks. I will be very grateful.
Aa Tuning bigred318 3-Series (E36) 5 01-18-2005 12:36 AM
Non-electric To Electric Seats RedlinedRU 3-Series (E36) 7 12-19-2004 07:31 PM
Es Tuning Exhaust Aggieland81 3-Series (E36) 2 10-10-2004 11:38 PM
which one is better for tuning? CSL Bimmer Talk/Motorsports Talk 1 04-05-2004 01:33 PM
Tuning BMWGUY445 3-Series (E36) 3 09-20-2003 10:21 PM
