hi there! strange messages on check panel in my 1993 540i : brake light+tail light+dip beam+lic.plate light. None of the bulbs/fuses faulty - any suggestions???THX
__________________ Member 150+ MPH club
Member of the 3-Pedal club
Memebr BMW FORUMS V1 CLUB
Check every light bulb you have first to be sure one isn't out and being mis-diagnosed by the ECU. You may have a short somewhere. I have also heard that some bulbs, I think if they aren't the correctly rated bulbs or something, will continually throw the check lights at you even though they've been replaced. Double check the wattage and all that for those bulbs you've replaced to be sure they aren't 1) underated or 2) overated for your car.
Good luck and wipe that smile off your face. NOW DAMNIT!
__________________ <span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
Thanks for your advice, the problem has appeared without any reason no repairs have been carried out. I did check all the bulbs, they are not blown but they do look blackish (overheated???) so I will change them plus I am gonna clean all the conectors. After removing all the fuses, error messages dissapeared, but brake light one came back few hours later and now is gone again??? Good fun...
wow, this could be a tough one. Which bulbs did you say were blackened? There is a good possibility you could have a faulty LCM. Check the bulbs, connectors, contacts and if any of the bulbs look "smoked" or black, then replace those with a good quality bulb, preferably a bmw bulb (believe me, it makes a difference). Report back with your findings soldier, DisMissed !
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
