E61 Tailgate window. How do I open? - BMW Forum - BimmerWerkz.com
Old 10-22-2010, 05:59 PM   #1 (permalink)
dimbim is on a distinguished road
I need to open the tailgate window to gain access to the hinges, where I suspect the wires are damaged.
I have removed the plastic panels in the tailgate, and removed the four pin plug from the window lock. Does anyone know what voltages I need to apply to each pin in order to pop open the window Please?
dimbim is offline   Reply With Quote
Old 10-13-2012, 01:14 AM   #2 (permalink)
jukkareu's Avatar
jukkareu is on a distinguished road
I have same problem.
How can I open that tailgate glas when the switch in the glas is not working.
Have anyboby wiring diagram of E61 touring 2008?
I would not want to break the back of the door upholstery, so that I can switch exchanged.
jukkareu is offline   Reply With Quote
Old 10-13-2012, 05:12 PM   #3 (permalink)
Open glass panel of tailgate.
It is a long time since I posted the request for information.
Yours was the first reply.
Soon after posting, I found out the answer myself. This is what I remember from about 2 years ago.
I removed the panel on the inside of the tailgate.
Somewhere in there was a plunger, or pull lever.
When I applied the required pressure, (in or out) the glass panel flipped open.
Remove as much as possible and get your hands in there and pull and push, and you will find that the window will open.
Something I have learned since, is that the glass panel will not open (with the switch) when the main tailgate is already open, so it is just possible that you will have to perform the above from inside, with the tailgate closed, though I don't remember that being the case.
The repair on mine turned out to be a wire disconnected at the base of the switch, so really easy to fix.
I wish you luck with this. Have a try, and if you fail, post a reply, and I will have a re-think if necessary.
Best wishes. James
Old 10-14-2012, 02:22 AM   #4 (permalink)
jukkareu's Avatar
Thanks for the reply.
Did you get disconnected from the inside panel, without that you got the glass open. At the top of it is I think the two screws to the panel is closed. at the bottom of the panel is also in a tight lock around it.
Old 10-14-2012, 03:06 PM   #5 (permalink)
Tailgate.
I think I remember trouble getting in. My remedy was to remove the all the screws possible, and get my hand up and in there.
Have a go, and if you fail, write again, send your e mail address, and I will remove the panel, and refresh my memory, and then send you a diagram, so maybe you can poke something in.
Mine is a 2006/2007 e60 touring . Is your model similar?
jamesb@wtic.co.uk
Old 11-08-2012, 06:36 AM   #6 (permalink)
jukkareu's Avatar
Hello,
I have not managed to open the rear glass.
Would it be possible that if you opened your upholstery, and give information about what would that I might have to pull open the glass.
Old 11-15-2012, 04:43 PM   #7 (permalink)
OK
I had a look this afternoon.
I took off the panel completely, but, of course, you will not be able to do this.
Remove as many screws as possible, and the two black plugs, one on each bottom corner.
This should allow you to push out the bottom enough to look inside.
I took the red plug out of the electric lock, which is up near the window, the plug is on the left hand side, near the middle.
I couldnt find out which pin to apply 12v to, so I took pot luck, and it pinged open.
Today I noticed that on the cable harness coming from the left, there was a plug. This one had at least one cable going up to the lock.
What I suggest is, if you have this on yours, that you apply a voltage to either, in turn, and see what happens.
I have photos, so let me know if you need to see them. (Not sure how I will do that.)
Good luck.
James
Quick query E39 /E61 Load (roller) Cover Banstead 5-Series (E12,E28, E34, E39, E60) 7 06-07-2009 12:53 PM
318ti tailgate hinges mising OEM Parts 0 02-02-2009 04:48 PM
My tailgate glass wont open on my Touring (Wagon) 320de46m47 3-Series (E46, E90) 4 03-05-2008 10:12 AM
Hatch Window Won't Open bkittle 5-Series (E12,E28, E34, E39, E60) 0 06-27-2005 04:43 PM
E-39 Touring Tailgate problem finbmw 5-Series (E12,E28, E34, E39, E60) 1 08-31-2004 03:28 AM
