E60 Maintenance Code resets - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 01-08-2010, 09:37 PM Thread Starter
davidburke is on a distinguished road
Let me start by saying, if someone already posted this, please send me the link. I am trying to figure out how to reset the maintenance codes for mocrofilters, and oil changes on my '04 E60 530i. Thank you for you any help!
davidburke is offline
post #2 of 5 (permalink) Old 01-09-2010, 07:40 AM
BrianXE36's Avatar
BrianXE36 is on a distinguished road
Firstly with the ignition switched on, set the odometer trip meter back to zero by pushing it once. Then switch the ignition back off again. (I found this step was critical, otherwise I couldn't get to the "Service" menu).
Now you are ready to go through the reset steps as follows:
1. Switch the ignition on (so that the battery, Oil and Parking brake lights are displayed) and the key is ready to start the engine - but don't actually start the car.
2. Press the odometer reset button for between 5 and 10 seconds until a yellow triangle with an exclamation mark in the centre appears in the top window between the clocks (where the outside temperature / time or date normally appears) - this is the "Service" icon.
3. Release the odometer button briefly and press again straight away which brings up a picture of the Brake Fluid symbol (same as the one that the i-drive shows when you look at the Service menu).
4. If you want to reset the Brake Fluid interval for another 2 years then keep holding the odometer button until the word "RESET?" appears at the bottom of the lower window.
5. Release the button briefly and push it in again and hold for about 5 - 10 seconds until the new date appears in the bottom window. You can then switch the ignition off and the new Brake Fluid date will appear in the service menu on the i-drive screen next time you switch on.
6. If you want to reset the Oil, Microfilter or Brake Pad indicators then you will need to follow the same sequence as steps 1 and 2 above, but when you get to step 3 and the brake Fluid icon appears, just release the button and press again and the next service item will appear.
7. You can continue releasing and pressing the button until the required service item icon appears for the one you want to reset. As soon as it does then hold in the button in until the word "RESET?" appears again as in step 4 above. Once the word "RESET?" has appeared, you need to release the button briefly and hold it in again for about 5 - 10 seconds until it is replaced by the new service interval figure (as per step 5 above).
Hints & Tips
Before actually resetting anything, go through steps 1, 2 and 6 above until you are familiar (and sure) what you want to reset. Practice this a few times and note down in what order the icons appear after the initial "Service" icon appears.
If you do happen to hold the button down too long against an item you don't want to reset and the "RESET?" appears, just leave the button alone for 10 seconds or so and it will not let you reset the item. (Alternatively just switch the ignition off and start again).
Sometimes if you have not released and pressed the button again quickly enough, when you hold it down again the German technical writing will appear after about 15 - 20 seconds instead of the Service item icon you were expecting. (If this happens just switch off the ignition and start again).
Once you are sure what item you want to reset and are confident of the sequence, then give it a go. If you do hesitate between releasing and pressing the button at any time, you will have to go back to the beginning and start again as "he who hesitates is lost".
Source: How do you reset service light bmw e60? - Yahoo! Answers
BrianXE36 is offline
post #3 of 5 (permalink) Old 01-09-2010, 09:15 AM
Help from over the pond
marti5's Avatar
Very handy information.
marti5 is offline
post #4 of 5 (permalink) Old 01-09-2010, 03:03 PM Thread Starter
Thank you for your help! That is exactly what I needed!
Dave
post #5 of 5 (permalink) Old 01-17-2010, 11:38 AM
rabbit2001 is on a distinguished road
Brake pad service reset?
I followed the thread below and reset my 05 reg 525d service bits and bobs but then tried doing the same for the front brake pads, only to find the service due mileage changed from 2000 miles to 9000 miles ago and all the red service lights come on on engine start. Any ideas how to reset the brake pads service mileage please.
Cheers
Paul
rabbit2001 is offline
Would 525i (E60) brake pads fit on a 530i (E60) please help me on this one!!!!!!!!!!! bozope 5-Series (E12,E28, E34, E39, E60) 1 10-09-2009 07:11 PM
E60 Airbag code 93FC normanahoyt 5-Series (E12,E28, E34, E39, E60) 0 08-01-2008 06:14 PM
Maintenance Qs fushuman 3-Series (E36) 4 10-18-2004 04:57 PM
maintenance schulman 3-Series (E36) 14 06-16-2004 10:56 AM
Maintenance jennsydandrew 3-Series (E36) 9 03-31-2004 02:05 AM
