E60 545i 2003 Steering noise - BMW Forum - BimmerWerkz.com
Old 08-18-2007, 05:58 AM   #1 (permalink)
meditek2 is on a distinguished road
My car has only done 10,000 miles despite it's age! I am getting a slight clunk/knock noise that I can also feel through the steering wheel though it is very slight.
1. it seems to require that things are warmed up.
2. the slight clunk can happen at any point in the wheel arc.
3. There is a slight delay involved. eg if I turn the wheel say 20 degrees there is a tiny pause before the clunk. Sometimes the clunk does not happen until I start straightening the wheel and then it happens as I am moving the wheel.
I'd appreciate comments from anyone who has actually had this problem.
Thanks
meditek2 is offline   Reply With Quote
Old 08-18-2007, 08:30 AM   #2 (permalink)
isherdholi's Avatar
isherdholi will become famous soon enough
I've never had this problem myself, but some general advice would be to make sure there isn't something stuck to the tyres on the inside, which could be rubbing againsts the wheel arch/well. Sorry if thats a bit too obvious, or if you may have already done this.
isherdholi is offline   Reply With Quote
Old 08-18-2007, 11:15 AM   #3 (permalink)
Someone in the UK (where I live) sent me this. It seems that US cars are not affected but it's my first lead :-
Could this be the fault?
Complaint
An intermittent cracking or clunking noise can be heard when the steering
is turned at low speed or when manoeuvring
Production period concerned: E65/E66: Start of series production up to week
29/04.
E60/E61/E63/E64, all right-hand-drive vehicles.
The only left-hand-drive vehicles (LHD) affected are vehicles with an N62 engine:
Start of series production up to week 26/04.
Important:The E60,E61, E63 and E64 are only affected by cause 2. Thus only measure 2 provides a solution. Carry out measures 1 and 3 only on the E65/E66.
Causes:
1. The tightening torque of the bolt securing the bottom of the steering spindle to the universal joint with corrugated tube has changed.
2. A gentle cracking noise from the telescopic toothing at the bottom of the steering spindle may be produced when the steering wheel is turned or when the steering column height is adjusted. This noise is caused by a slip-stick effect.
3. Burring can be detected on plastic bearing rings manufactured between 12/03 and 04/04. This burring can result in a cracking or grinding noise in individual cases.
Service measures:
Concerning cause 1: Replace the Torx bolt securing the bottom of the steering spindle to the universal joint with corrugated tube and tighten it to a torque of 28 Nm (refer to current EPC for Torx bolt). The torques in TIS are being updated accordingly.
Concerning cause 2: Treat the telescopic toothing on the steering spindle with a lubricant spray. BMW part number: 83 22 0 397
761
Concerning cause 3: Fit a new plastic bearing ring, BMW part
number 32 30 6 756 512 (see Repair Instructions 32 31
102).
Old 10-28-2009, 02:58 AM   #4 (permalink)
slavisa is on a distinguished road
Hi,
what happened with your clunking issue? What was the reason?
I have a similar problem.
slavisa is offline   Reply With Quote
Wind noise -2003 325i stephen4080 3-Series (E46, E90) 5 02-01-2004 11:34 PM
BMW Group Sales for 2003 Stacy540i Bimmer Talk/Motorsports Talk 0 01-05-2004 01:10 PM
