E60 530i 2007 vibration at idle speed - BMW Forum - BimmerWerkz.com
Old 07-13-2012, 04:35 PM   #1 (permalink)
nazab is on a distinguished road
Question E60 530i 2007 vibration at idle speed
My E60 530i 2007 suffers from a clear vibration at idle speed that you can clearly feel when holding the steering wheel or the gearshift . The RPM needle is very stable without any fluctuation at idle at about 600 RPM, and as i slightly increase the RPM to 1000 RPM the vibration disappears . However, when settles down to 600RPM you feel the vibration again in the steering wheel.
Comments please if anyone has faced this problem and how was it cured ..
nazab is offline   Reply With Quote
Old 07-13-2012, 08:39 PM   #2 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Is this while driving or stationary?
Click HERE to see my E36 Blog
Old 07-14-2012, 05:06 AM   #3 (permalink)
stationary while gearshift is in neutral position or in drive position .
Old 07-14-2012, 08:01 AM   #4 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Have you taken a look at your engines transmission mounts? Make sure their not worn out.
Old 07-14-2012, 03:31 PM   #5 (permalink)
As the car is relatively new , I didnt consider this as it is more popular in much older cars . Anyway, will check this as well . Some have mentioned changing the spark plugs can solve this problem too . Will try this as well and see.
Old 07-16-2012, 02:17 AM   #6 (permalink)
koason is on a distinguished road
is it easy to intstall?
www.koason.com
koason is offline   Reply With Quote
Old 07-16-2012, 10:42 AM   #7 (permalink)
Lord Vader's Avatar
Car: 1998 E36 328i
Just because the car is newer doesn't mean the mounts can't fail or have worn out. Let us know if new plugs help
Old 08-18-2012, 03:53 AM   #8 (permalink)
ckng is on a distinguished road
I'm driving a 2007 E660 and having the same steering wheel vibration when idle only at 830 rpm with or without A/C on. Any idle rpm of below or able 830rpm, the vibration will just goes away. Workshop did tried to tune the idle rpm down to 700rpm. But a soon as I start my car, the engine will automatically raised back to 830rpm and needle is stable at that rpm. The only time the idle speed would drop back to 700rpm is when I start my engine when outside temp is less than 25 degC. Somehow felt that it is temp related. But nobody seems to be ble to find the causw
ckng is offline   Reply With Quote
Old 08-18-2012, 07:24 PM   #9 (permalink)
Angry
Changed the spark plugs, but the problem is not solved ! same problem still exists !
Old 08-24-2012, 07:26 PM   #10 (permalink)
I have changed all the spark plugs and injector coil,
Replaced the engine mount. And the steering wheel
Vibration is still there. The only time I would experience
A idle without the vibration is when I start the car when the
Outside temp is below 25 degC. Once the outside temp
Rises to 28 degC or higher, the idle vibration is back.
I strongly feels that it has something to do when
Tenperature
Old 08-31-2012, 03:58 PM   #11 (permalink)
gmcclintock is on a distinguished road
I also have a e60 that the wife drives and her car does the same thing I searched the froum I'm on bimmerfest and came across this a few years ago.
Service Bulletin 18 02 08
Customer may complain of a slight vibration and/or droning noise when the vehicle is idling in park, neutral, drive and reverse when engine is at operating temperature.
CAUSE
Insufficient vibration dampening of the exhaust system.
PROCEDURE
1.Verify the complaint. Vibration/droning is most prevalent when engine is at operating temperature.
2.Remove the lower bracket for the exhaust system. If droning/vibration is gone, proceed to step three. If vibration/droning still exists with the lower bracket removed; continue troubleshooting exhaust/driveline for other causes or conditions
3.Remove complete bracket assembly and replace it with the bracket (1) PN 18 20 7 521 346 using two new ASA bolts (PN 07 12 9 905 417. Tighten to 21Nm.
Install front pipe bracket (1) PN 18 20 7 521 347 with four rubber bushings (2) (PN 18 20 7 546 579) to the new 346 bracket with two ASA bolts (PN 07 12 9 904 559) and two nuts (PN 07 12 9 904 580). Tighten down to 21Nm
After performing this procedure the vehicle will exhibit the same amount of normal driveline vibration as a comparably equipped E60 with a M54 or N52 engine.
Link to the thread can be found here. Good luck
gmcclintock is offline   Reply With Quote
Vibration on speed 30 or 40 miles alirzn 5-Series (E12,E28, E34, E39, E60) 11 07-05-2012 08:12 AM
vibration at idle bmwKing95 3-Series (E36) 9 05-22-2009 10:38 AM
vibration at highway speed RichB 3-Series (E21, E30) 6 09-12-2008 08:30 PM
Low Speed Driveshaft Vibration jazzbass 5-Series (E12,E28, E34, E39, E60) 1 10-07-2005 08:28 PM
Vibration at a particular speed only, Why ? beautyland 5-Series (E12,E28, E34, E39, E60) 7 06-23-2004 08:58 AM
