E39_Shift points - BMW Forum - BimmerWerkz.com
Old 10-15-2010, 06:44 PM   #1 (permalink)
Car: 97/540i
frankyvero is on a distinguished road
E39_Shift points
The shift points are messed up on my 97 540i automatic. When shifting from N to D it jerks pretty hard forward. N to R- normal. When normal driving in D the shift points are early until it gets to 3 then it is early. It wont shift from 4 to 5 without going quickly to N (lowering the RPM). When in 4, if I floor the peddle to downshit- it wont. When in Sport: 2 is normal but it wont upshift if I hit the rev, and if I manually shift to 3 it wont shift. The transmission has no codes according to the indy shop. Is this something to do with the MAF or the TPS or misadjusted throttle cable ??????
frankyvero is offline   Reply With Quote
Old 10-16-2010, 05:55 PM   #2 (permalink)
Car: 97/540i
Okay, the problem was: Had the wire harness switched between the TPS and the ICV. This was done after I cleaned the throttle body.
Old 10-16-2010, 07:46 PM   #3 (permalink)
Glad it's sorted, thanks for sharing the solution.
Old 10-26-2010, 04:28 PM   #4 (permalink)
BBenedict's Avatar
Car: 2002 BMW 540i, sport package
BBenedict is on a distinguished road
Another thanks for sharing the solution. It's great when folks report their fix to a
problem.
BBenedict is offline   Reply With Quote
Jacking Points Hootie 3-Series (E46, E90) 2 04-17-2006 09:35 PM
Grease points Zq-8_dawg 3-Series (E36) 2 08-29-2004 08:01 PM
Grease points Kiwi Russ 3-Series (E36) 1 07-08-2004 08:43 PM
F1 points standings lwebb12 Bimmer Talk/Motorsports Talk 3 09-16-2003 07:12 PM
