E39 suspected head gasket problem - BMW Forum - BimmerWerkz.com
Old 07-18-2008, 01:03 PM   #1 (permalink)
JMTC is on a distinguished road
Hi I have a 528 which I have owned from new, now reaching its 10th birthday, it only has 130,000 miles being now relegated to second car. It has a slight smell of anti freeze after driving it and just the smallest trace of scum under the oil filler cap when I checked. However water level fine and no movement of temperature gauge.
Is this an early warning sign of head gasket problems? Hope not as love the car and shame to get rid of it as it is of no commercial value. Any advice welcomed
JMTC is offline   Reply With Quote
Old 07-18-2008, 11:52 PM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
it's not set in stone... but yes... trace of moisture in your oil cap can be diagnosed to be a cylinder head gasket going bad.
if you use detergent oil/s then yes, it's also possible that u can get traces of scum(as u say) in your oil cap.
Other indications will help to confirm cylinder head gasket problems. as in rough/uneven idling; loss of coolant; overheating; in conjuction with the scum that you see.
If you are not experiencing any of the above, it could just be contaminated oil.
Old 07-19-2008, 02:21 AM   #3 (permalink)
Thanks, thinking about it I did change the oil recently and flushed first so perhaps this is just a consequence of the flush - guess the best thing is to keep a check on the coolant, car still idling like only a BMW can!
Blown head gasket, Cracked cylinder head... Blackoutmp M-Series (M1, M3, M5, M6) 8 04-04-2006 01:51 AM
Head gasket problem? Uh, oh. ozarkmark 5-Series (E12,E28, E34, E39, E60) 5 02-27-2006 11:39 PM
Help Does A Blown Head Gasket/head Make Noise? E36k224 3-Series (E36) 7 03-17-2005 12:18 PM
Loud Engine Noise And Head Gasket Problem dshrewd1 3-Series (E36) 0 11-12-2004 04:25 PM
Blown head gasket, new motor or new gasket? Bmw528i 5-Series (E12,E28, E34, E39, E60) 9 07-07-2004 01:06 AM
