| E39 Sporadic Electrical Faults '98 E39
Anyone have trouble with the following sporadic problems after having started the ignition?:
Some of the door or trunk ajar warnings on but doors/trunk are actually closed
All turn signal and 4-way hazard fllashing lights inoperative
Shut and re-start the ignition and above problems disappear??????
At other times ignition does does not work, - take out the key and try again -and all is well.
I'm thinking it's the ignition switch. |
