E39 Speedo intermittent - BMW Forum - BimmerWerkz.com
Old 08-19-2009, 02:19 AM   #1 (permalink)
Car: Black 2001 530i
mikkey9289 is on a distinguished road
Send a message via AIM to mikkey9289 Send a message via Yahoo to mikkey9289
My 01 530i has been having some issues lately. It started with the DSC/ABS lights being intermittent on and off. ABS and DSC functioned when off and did not function when the lights were on. The lights are now permanently on. Now the Speedo is intermittent. I was willing to live with the lights, but now that the speedo is acting up i am really concerned. I have a general mechanical backround. I have been reading about alot of issues with the ABS ECU causing similar problems, but they never covered the Speedo. Also when the speedo is out the Odometer stops registering, and the economy meter stops working.
thanks,
mike
The 01 530i is sweet, but the 87 supra is quicker.
mikkey9289 is offline   Reply With Quote
Old 08-19-2009, 02:42 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Arrow
Got access to an OBD2 scanner? That would be the easiest way to start diagnostics. :-)
In the absence of a scanner, take a chance and clean the wheel speed sensors, the rear ones especially. ABS takes it's signals from those sensors too.
Pay close attention to the LH wheel sensor-the speedo relies on that signal for it's operation ;-)
From syptoms you describe, it's possible it is just that.
Clear the light and re-test :-)
Good Luck
Old 08-19-2009, 03:48 AM   #3 (permalink)
Car: 1997 E39 540i
harryinsaudi is on a distinguished road
yes, LH rear sensor, if it's intermittent you've probably got a chafed cable... take it off and inspect it you can tapeit/shorten it a bit if needed.
harryinsaudi is offline   Reply With Quote
intermittent gauge problem on my 95 m3 HELP!! My3rdBimmer M-Series (M1, M3, M5, M6) 4 08-16-2006 09:25 PM
intermittent gauge problem on my 95 m3 HELP!! My3rdBimmer 3-Series (E36) 5 08-03-2006 01:20 PM
Intermittent Prob 1985318i 3-Series (E21, E30) 2 10-26-2004 11:48 AM
intermittent wiper function nycbmw325is 3-Series (E36) 11 08-06-2004 12:25 PM
Intermittent Blower Problem ianrigg 3-Series (E36) 0 05-13-2004 04:55 AM
