E39 Rear Wheels - BMW Forum - BimmerWerkz.com
Old 07-18-2005, 06:50 AM   #1 (permalink)
stealthsmooth is an unknown quantity at this point
Thumbs down
hello all
I have a set of rondell on my rears. thses are 10*18 with 265.35.18 on.
my car has been lowered by 40mm and the wheel has been scrapping in the inner arch. If i was to put my orginall suspension back on will this eliminate the problem as the car will be sitting higher? pls. advice as I need to get this problem sorted before I distroy my 2 new tyres. thanks. ghead
stealthsmooth is offline   Reply With Quote
Old 07-19-2005, 11:18 PM   #2 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
What you could do is roll the rear fenders. It's a very common practice procedure, especially for a lowered car with wider tires. This would probably be a cheaper option for you than redoing your suspension back to stock because changing out the BMW suspension + alignment can be costly if done by a shop. And to give an educated guess on your question, yes I do believe returning to your stock suspension would alleviate this problem, but if you have many passengers in the rear seats it may return.
Roll your fenders, Good Luck!
Old 07-20-2005, 03:54 AM   #3 (permalink)
hitz is an unknown quantity at this point
[snapback]363663[/snapback]
i've already rlled the fenders. what i done is change the style of the rear tyres to ones without no edge protector. i think thats solved the problem. hopefully.
cheers
hitz is offline   Reply With Quote
Old 07-20-2005, 03:44 PM   #4 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
Sorry, but what is a "edge protector?"
Old 07-21-2005, 02:39 PM   #5 (permalink)
tacroteau's Avatar
tacroteau can only hope to improve
Send a message via AIM to tacroteau
I believe he is referring to the design where on LOW profile tires, when you hit a pothole, the tire compresses, and squeezes out a chunk of rubber from the sidewall, that covers the outside lip of your rim. I have these on mine(see pict) and withought them I'd be screwed. It really saves your rims.
[snapback]363852[/snapback]
tacroteau is offline   Reply With Quote
Rear wheel angle BMWhatever 5-Series (E12,E28, E34, E39, E60) 15 11-16-2005 06:34 AM
Metallic Friction Noise At Rear Wheels mostwired 3-Series (E36) 1 08-25-2005 07:19 PM
Car Feels Wobbly In Rear Wheels At 50 Mph! Delmarco 3-Series (E36) 5 10-04-2004 08:03 AM
First look and info on the 2005 Acura RL AWD! AZ325Ci Other Rides 2 06-23-2004 09:23 PM
noise out of front and rear driver's wheels debbie M-Series (M1, M3, M5, M6) 5 11-22-2003 05:25 AM
