E39 rear lower bushes - BMW Forum - BimmerWerkz.com
post #1 of 2 (permalink) Old 05-27-2009, 04:30 AM Thread Starter
martinwillmott is on a distinguished road
Located in the rear lower control arms, jack up the car and check for play top to bottom in/out movement on the wheel, I had quite a bit of play at the bottom, seems the local parts supplier GSF Daventry sell loads of bushes for these cars although it's technically a ball joint it looks like a bush, The removal of the old one was an absolute nightmare, first remove the retaining clip (snap ring) we heated it up, we tried knocking it through, we made up a puller, took ages to get this thing out! at one time it was considered to remove the entire hub and work on it off the car but even that's a job in itself. eventually got it out with heat muscle, patience and a puller, fitting the new one was a lot easier after a cleanup with a dremmel. the problem seems to be a combination of the thing was pressed in with a ridiculous amount of force in the first place and the usual reaction between steel and aluminium.
If you are not brave or equipped with a gas torch and puller, don't even attempt getting this out, you'll be far better off getting a local garage to do it. I will next time!
martinwillmott is offline
post #2 of 2 (permalink) Old 05-27-2009, 11:17 PM
mrmojo37's Avatar
mrmojo37 is on a distinguished road
I did mine but I took the time to make a press to press the old ones out. I used huge sockets, threaded stock and nuts that I borrowed from a friend to press the old ones out. I put my new ones in the freezer overnight so they would contract a bit and used sockets with threaded stock, washers and nuts to press the new ones in. It was a Bitch but i did both in about 4 hours in my garage. There is a tool/press you can buy but it costs about $300. Go to this link. It outlines the job so you can prepare for everything like I did.
Beisan Systems - Procedures - Swing Arm Ball Joints Procedure
mrmojo37 is offline
E39 lower eyelids? BallisticLegend 5-Series (E12,E28, E34, E39, E60) 1 09-13-2005 08:23 PM
Wishbone/rear Lower Control Arm doughnutboy 3-Series (E36) 3 08-21-2005 10:02 PM
Rear Subframe Bushes CaptainEL 5-Series (E12,E28, E34, E39, E60) 3 02-04-2005 03:24 PM
Rear Sub Frame Bushes CaptainEL 5-Series (E12,E28, E34, E39, E60) 4 12-22-2004 05:27 PM
to lower or not to lower the E39.... t0nyd4tiger 5-Series (E12,E28, E34, E39, E60) 10 06-24-2004 04:04 AM
