E39 Radio Removal - BMW Forum - BimmerWerkz.com
Old 06-09-2005, 03:13 PM   #1 (permalink)
mdimbler is an unknown quantity at this point
Thumbs up
I am trying to remove the radio/MID in my 97 540 and I cannot get it. I have read all the posts here as well as other bmw web sites pertaining to radio removal. When I remove the volume knob, I see the silver slotted screw that the knob goes on, a hexagonal nut around the egde of the knob screw, and a small slot at about the 6 o'clock position underneath the knob screw. It is my understanding that there is a torx screw in that slot. I bought a few different torx screwdrivers (size 5, 7.5 and 10), but when I put them in the slot underneath the knob, they just move all the way in up to the hilt of the screwdriver. It is as if there is no screw in there. Am I going about this all wrong, missing a step? Any help is appreciated.
mdimbler is offline   Reply With Quote
Old 06-09-2005, 04:25 PM   #2 (permalink)
beaker is an unknown quantity at this point
[snapback]352094[/snapback]
I believe there are two different methods that BMW used for holding the radio in, one uses the torx screw method and the other uses a spring loaded catch (like mine). There should be a vertical slot just to the right (3 O'Clock pos'n) of the volume control shaft. Put a flat bladed screwdriver into this and push it to the right. You should feel the catch move against the spring pressure. While keeping the sideways pressure on pull the screwdriver towards you slowly and the left hand side of the radio should hinge out. Take out the screwdriver and you should now be able to remove the radio quite easily.
Hope this works for you
beaker is offline   Reply With Quote
Old 10-07-2008, 04:53 PM   #3 (permalink)
j2552513 is on a distinguished road
Hi guys,
I've followed the instructions though the left hand side of the radio is hinged out but the right hand side is not coming out.
Anyone to help, please.
Thanks
j2552513 is offline   Reply With Quote
Old 10-13-2008, 08:02 AM   #4 (permalink)
MrClem08 is on a distinguished road
I am trying to remove the factory speakers from my 540 any help out there for me?
MrClem08 is offline   Reply With Quote
Old 10-13-2008, 01:49 PM   #5 (permalink)
SOL_540iA's Avatar
SOL_540iA is on a distinguished road
E39 Radio
If you have still not been sucessfull in removing the radio, you may try the following:
(1) Remove the radio power/volume knob (you have already done that)
(2) A small hole will be revealed at 6 O'clock position. Use a bright light to locate a 2mm allen screw inside the hole.
(3) Engage a 2mm allen key and turn about 90 degrees. This will retract spring loaded tabs holding the MID.
(4) While still holding the allen key twisted, gently pull out the MID
Hope this helps
Sol.
SOL_540iA is offline   Reply With Quote
Old 10-13-2008, 01:55 PM   #6 (permalink)
SOL_540iA's Avatar
If your car is like mine, there are 10 speakers installed. 4 in the front doors, 2 in the rear doors and 4 in the rear parcell shelf. You didn't say which ones you were trying to remove.
Sol
Old 09-10-2011, 02:27 PM   #7 (permalink)
dluckie1 is on a distinguished road
Hi guys,
Trying to install the Dice 1500 multimedia bride in my 2002 530i. The car install shop mentioned when they tried to remove the radio, the hex screw in the 6 o'clock position behind the Volume Knob is stripped (rounded out). They said they cannot remove the radio without ripping it out and forcing me to purchase another from them. Any suggestions or should I return my Dice Multimedia Bridge and call defeat? Any help would be appreciated.
Thanks kindly
dluckie1
dluckie1 is offline   Reply With Quote
Old 09-10-2011, 02:46 PM   #8 (permalink)
SOL_540iA's Avatar
Well if you are going to discard the factory radio (MID) then I would suggest to place a drop of super glue on the tip of a 2mm allen wrench. Gently inset the allen wrench into the small hole at 6' O'clock. Ensure that the allen wrench has embedded itself in the rounded allen screw. Allow the superglue to set. Then turn the allen wrench through 90 degrees pulling the MID at the same time.
Hope that helps.
Sol
Old 09-23-2011, 08:18 AM   #9 (permalink)
darrylgough is on a distinguished road
BMW Audio
You do realise that BMW audio is already top grade components made by Alpine. That is all I have to say.
darrylgough is offline   Reply With Quote
Old 09-29-2011, 10:21 PM   #10 (permalink)
ozx5 is on a distinguished road
I have the factory sat nav small screen system and want to remove the timber facia.
Can anyone give me a heads up on how that sucka pulls off.
ozx5 is offline   Reply With Quote
Radio Removal Screw- Bentley Manual Disappointment BlackinBlack 5-Series (E12,E28, E34, E39, E60) 6 11-13-2011 12:00 AM
Vanity Mirror Causing Radio Prob. dell 5-Series (E12,E28, E34, E39, E60) 1 12-14-2004 12:41 PM
'04 525 Radio Problems BMarcW 5-Series (E12,E28, E34, E39, E60) 2 11-11-2004 07:22 AM
radio removal DIY FAQ? sy5alive 3-Series (E36) 2 07-29-2004 09:43 AM
1995 740i Radio / Audio System wmccally 1,6,7,8 - Series and Mini Cooper 1 04-19-2004 12:11 AM
