E39 Passenger Window button works but.. - BMW Forum - BimmerWerkz.com
Old 05-14-2008, 02:05 PM   #1 (permalink)
zork007 is on a distinguished road
the drivers side does not... Also mirror button does not work and lock does work on passenger side.
Any suggestions??
zork007 is offline   Reply With Quote
Old 05-15-2008, 11:11 AM   #2 (permalink)
winters97E39's Avatar
Car: 1997 BMW 528i
winters97E39 is a jewel in the roughwinters97E39 is a jewel in the roughwinters97E39 is a jewel in the rough
Send a message via ICQ to winters97E39 Send a message via AIM to winters97E39
Any suggestions??
Drivers side button for the passenger side window doesnt work? Or does the driver's side window not roll up/down?
On the lock, what do you mean? door locks are central button in the center console on E39.
Check the connections to the buttons for the window and the mirror, take them out, clean them up good. Sometimes the contacts can get dirty and then they no longer make electrical contact.
A suggestion for future posts: be very specific in your questions, and add any troubleshooting you may have done already.
Jason / 1997 528i
winters97E39 is offline   Reply With Quote
Old 05-15-2008, 05:14 PM   #3 (permalink)
First let me thank you for the help.
Well I quess I didnt make it clear..but Drivers side button for the passenger side window doesnt work. Drivers side window does roll down. The buttons on the drivers side dont roll down the window or allow me to adjust the mirrors (both sides)
As far as the locks are concerned...I can lock and unlock all doors ..except the passenger side. The center console button and the key lock does not unlock the door or lock it. I have to manual open the door with the inside handle to unlock it.
Also I dont know if this will have any bearing on this but..my car was broken into a few months back and they smashed the passengers side window. a month or so I started having problems with that lock.
You mentioned the switches may need to be cleaned...is there a diy that can help me out with this? Any help would be most appreciated. IMO I believe it is the switches in the drives side door cuz it just makes sense...although since owning this BMW I can say some thing just dont make sense.
Speaking of which...I have owned many cars in my days and I must say this car is the ultimate, love driving it and I wish I would have gotten one a long time ago!
Thanks
Mark
Old 05-16-2008, 12:16 PM   #4 (permalink)
Car: 1997 BMW 528i
no DIY's that I know of, but it should be pretty straightforward. I can't remember off the top of my head if the buttons will come out without having to take the door panel off, but I would take the door panel off first just to be safe. It comes off easy enough anyway, it is just pressed into the door with plastic clips. be gentle, but firm when pulling it off, so that you don't break any of the clips. Anyway, once you get the button module out, it should be readily apparent how to clean up the contacts, or take it apart (if that is possible) to get into the meat of things. When I say clean, i mean look at any place where metal makes contact on metal to complete an electrical circuit. If there is any gunk on the metal, then the contact can't be made, hence the switch won't do its job. Just take a little wd-40 or something like that (sparingly!) and some q-tips and that should do the trick. Honestly, I haven't had to do this with my Bimmer, but my previous car (Honda Prelude) did the exact same thing that you explain for the passenger side window. I was able to take the driver's side button cluster completely apart, cleaned up the electrical contacts and when I replaced it back, everything worked like a champ. Same thing happened on my Yukon that you described for the side view mirror adjuster. Just took the button apart, cleaned up the contacts where the button makes the electrical connection, and voila! mirrors started working fine again.
On the lock, sounds like the lock mechanism on that door is either broken, or disconnected. Take the door panel off and do an investigation.
Jason / 1997 528i
Old 05-21-2008, 04:32 PM   #5 (permalink)
Thanks again for the help. I took the drivers side control panel out and took apart the unit but there was not any metal to metal contacts to clean. Basically there is a circuit board with tiny (1cm) metal buttons for each switch..there were 3 for each rocker switch. This board was then covered with a thin rubber overlay. Then there was plastic parts for each switch so when you hit the rocker switch it clicked one of the metal buttons.
Well after taking that out Ive come to the comclusion that maybe its not in either of the door switches but maybe in the wiring that leads from the switch box to the other the actual component (ie mirror, window ) Is there a relay in between these two.
Anyways thanks for your help
Mark
Need help to fix passenger window. Ocean02 3-Series (E46, E90) 6 03-24-2006 10:40 AM
Rear Passenger Window drmorf 5-Series (E12,E28, E34, E39, E60) 2 05-27-2005 08:18 AM
Passenger Window john_18 3-Series (E36) 0 12-28-2004 08:16 AM
Passenger Window Exterior Trim epistemology 3-Series (E36) 5 09-27-2004 03:28 PM
PASSENGER WINDOW TROUBLE ldsbeaker 3-Series (E21, E30) 6 06-14-2004 10:43 AM
