E39 Overheating coupled with failure to start - BMW Forum - BimmerWerkz.com
post #1 of 3 (permalink) Old 02-17-2010, 02:10 PM Thread Starter
happy2toes is on a distinguished road
Someone please help me! I have a 1997 BMW 528 that I LOVE and had a very strange issue yesterday. In the morning my car started to overheat so I pulled over checked the upper/lower radiator hose no leaks nor any leak from the radiator. Let the car sit for 10 minutes, then it was fine for the next 5 hours. Later in the day same problem. I let the car sit and this time I could only drive for about 1/4 mile before I had to kill the engine. I did this for a couple miles then called a tow truck. When the tow truck dropped my car the behicle wouldnt start at all. The accesory lights came on but nothing from the started. A jump wouldnt work either. I thought my thermostate or water pump was the issue but now I am worried its something much greater like a head gasket? Could I have seized the car? I killed the engine every time it reached a certain point. Also the belt is in tact. Anyone have any thoughts I would greatly appreciate it....
Steve
happy2toes is offline
post #2 of 3 (permalink) Old 02-17-2010, 02:49 PM
Help from over the pond
marti5's Avatar
You will have to remove the spark plugs, then get a socket on the bottom crankshaft wheel nut and see if the engine turns, make sure its in 'N'
marti5 is offline
post #3 of 3 (permalink) Old 02-18-2010, 01:33 AM
darkhorse737's Avatar
Quoted: 2 Post(s)
Cool
When you overheated, you reloaded coolant... BUT you did not bleed the cooling system and purge it of air bubbles/pockets trapped inside the engine. The bleeding process is a must for every bimmer, and air in the cooling system generates steam which the car reads as "overheat".
Confirm also that your engine did not blow a head gasket. check ur oil level... if it is abnormally high or "coffee n cream' in consistency and color... then that means that oil and water are mixing in ur system.
darkhorse737 is offline
intermittent start failure, when cold it won't turn over maxslomoff 3-Series (E36) 13 09-26-2011 10:15 PM
E39 528i overheating foru2justnvmoi 5-Series (E12,E28, E34, E39, E60) 6 03-23-2010 10:18 PM
E39 M5 overheating problem SpecialK 5-Series (E12,E28, E34, E39, E60) 1 04-29-2008 10:55 PM
97 528i (e39) overheating????? BALKAN 5-Series (E12,E28, E34, E39, E60) 7 12-30-2006 08:56 PM
E39 overheating? psubrizi 5-Series (E12,E28, E34, E39, E60) 5 08-09-2004 02:52 PM
