E39 License plate light - BMW Forum - BimmerWerkz.com
Old 04-08-2009, 05:18 PM   #1 (permalink)
KennnzoNy's Avatar
KennnzoNy is on a distinguished road
I was changing light bulb in my E39...and i pushed to hard and finally cracked licence plate housing, i was looking for that part in the web, but i cant find it...is it only available from the dealer ? thanks.
KennnzoNy is offline   Reply With Quote
Old 08-30-2009, 09:11 PM   #2 (permalink)
rbdimartino is on a distinguished road
license plate light assembly part number
Did you ever get a reply on this? I just did the same thing yesterday and then found that you need to slide to the right not the left. So now I need a new light assembly thanks to bad info in the owners manual.
rbdimartino is offline   Reply With Quote
Old 09-05-2009, 08:31 AM   #3 (permalink)
Car: 2001 BMW 525d auto
stevecvo is on a distinguished road
Yep I did the same. The owners manual gives incorrect info leading you to push the wrong way and break the casing. I sealed mine back in place. I took mine out to replace a bulb and found that there was no current down the wire. Rather than try and trace the break I simply spliced into the feed to the other light.
stevecvo is offline   Reply With Quote
Old 09-05-2009, 08:36 AM   #4 (permalink)
Found better replacements
So, I went on E bay and found LED replacement lights that are significantly brighter than stock. The LED's are part of the housing so rather than finding the replacement bulb and the replacement light assembly I just purchased two new LED assemblies.
They are worth the $60.
Old 09-05-2009, 11:04 AM   #5 (permalink)
Car: 91/BMW/535i
DonJ is on a distinguished road
Do you know the actual BMW part number for the license plate housing?
I have had luck putting the part number in to Google and finding on-line parts suppliers that carry the part.
If you don't know the part number - go to RealOEM.com they have diagrams for just about everyting including the BMW part number. They don't sell the parts but it gives you a part number to search on.
Good luck!
DonJ is offline   Reply With Quote
License Plate Light E26 323i Coupe not working Ncc1701a 3-Series (E36) 5 12-05-2012 01:59 PM
License plate light staying on BMWDriver1993 3-Series (E36) 5 01-30-2009 02:56 PM
rear license plate light spotteddog 3-Series (E36) 4 08-30-2006 07:29 PM
Computer Says License Plate Light Doesn't Work? BMWfiend 3-Series (E36) 2 03-20-2005 07:51 AM
License Plate Light Fail theholygoof 3-Series (E36) 12 01-21-2005 11:30 AM
